4G69 Oil analysis
Old Apr 22, 2008 | 09:19 PM
  #31
benny_ralliart's Avatar
ya, i use mobile 1 and i change it every 5000 km's and i dont even usually check it except right before the oil change to make sure it hasnt gone down. But i think im also going to extend my intervals between oil changes to at least 7000 km's.
Old Apr 23, 2008 | 04:11 AM
  #32
otter's Avatar
EvoM Administrator
I've found that, the older my car gets, the more it's using oil. Approx. 1/2 qt every 3k miles. Compression is still fine, though, at 200psi in all 4 cylinders.
Old Apr 23, 2008 | 08:13 AM
  #33
migs647's Avatar
I think I'm going to switch to Royal Purple. I wasn't that happy with Castrol Syntec. Seems it didn't last long... and when the car is cold it would knock a little. I switched to Mobil and it went away. Crazy how different oils can do that. The Syntec did the same thing to my gf's OZ Rally.
Old Apr 23, 2008 | 12:36 PM
  #34
otter's Avatar
EvoM Administrator
I'm starting to read that RP isn't that great. Stick with M1, it seems to test better than RP, or go with Amsoil.
Old Apr 23, 2008 | 01:15 PM
  #35
Eclipse2Lancer's Avatar
Plus M1 is much cheaper. Although I did put RP in my trans.
Old Apr 23, 2008 | 01:55 PM
  #36
Thomar's Avatar
i really wanna do an oil analysis but i cant find a place in Edmonton that does it..
Old Apr 23, 2008 | 02:13 PM
  #37
otter's Avatar
EvoM Administrator
If you order Amsoil by the case via Oil Doc, it comes out to the same price as M1
Old Apr 23, 2008 | 05:14 PM
  #38
Mr. Evo IX's Avatar
http://www.blackstone-labs.com/
You just order the kit, they send you everything you need, you send back the sample and get your analysis.
Read their FAQ, it's worth the effort.
Old Apr 24, 2008 | 06:36 AM
  #39
Joho22's Avatar
ive been a big fan of RP...
whats the downside to it?
I wasnt a fan of the M1 Synthetic, especially after the mishap and slipping of using the mobil 1 tranny oil.
Old Apr 24, 2008 | 08:22 AM
  #40
Achilles's Avatar
Im also a big fan fan of RP and have been using for quite some time now. Whats wrong with RP?
Old Apr 24, 2008 | 10:06 AM
  #41
otter's Avatar
EvoM Administrator
I'm just talking about the motor oil. For trans oil, I would only use OEM, BGII, or Amsoil. M1, even though they are no longer 100% synthetic, is still good motor oil, though.
Here's some reading - http://www.amsoil.com/lit/g2457.pdf
That's an Amsoil test, so it's a bit biased, but if you read around independant sites, they back up that data.
I'm curious to see how my analysis numbers compare. I just drained my oil (RP 5w-30) and took a sample to be mailed off. It was replaced with Amsoil 5w-30. So, in another 7-8,000 miles, we can compare my numbers.
Old Apr 24, 2008 | 10:14 AM
  #42
migs647's Avatar
Get to driving otter... I'm due in like 500-1k miles.
Old Apr 24, 2008 | 10:26 AM
  #43
otter's Avatar
EvoM Administrator
Don't worry, I'll knock out 7,000 miles within 3 months.
Old Jan 5, 2010 | 03:14 PM
  #44
Johnnus's Avatar
Hey Otter, I know this was like 2 years ago, but did you end up doing the analysis with the amsoil?
I'm about to get an oil change Amsoil along with the Ea oil filter which has a 25,000 miles or 1 year guarantee.
I figure, instead of oil changes every 8000km, 4 times a year. It'd be more cost efficient even to use the best oil and filter and run it for 24,000km or 9 months.
Old Jan 5, 2010 | 03:30 PM
  #45
otter's Avatar
EvoM Administrator
Nah, I never got around to doing another analysis. I really should, considering the age of my engine.
