supercharged, and turbocharged???
Old Dec 20, 2007 | 01:05 PM
heartagram88's Avatar
i was reading my issue of Modified Mag, and there was a Scion TC in there thaqt was both Turbo'd and supercharged....just curious if that combo would ever apply for our RA or is that something out of a Sci-fi movie for our cars...(meaning, could never happen)
Old Dec 20, 2007 | 01:09 PM
RoBear's Avatar
I guess it's possible, but I have a hard time imagining the benefit on a 4-cylinder
Old Dec 20, 2007 | 01:22 PM
EvoBroMA's Avatar
of course its possible. you can do anything with enough money. but its completely pointless. they've done the same thing to the integra. not sure why you would want more power down low, especially with FWD.
Old Dec 20, 2007 | 02:50 PM
HeRtYIXMR's Avatar
how is that possible? I guess the compressed air meets up in a dual header-like manifold? sketchy
Old Dec 20, 2007 | 03:03 PM
Cow town racer's Avatar
It would be similar to a twin turbo set up, with a smaller turbo and a larger one.
Old Dec 20, 2007 | 04:24 PM
shunderwunder's Avatar
There are turbo kits designed to work on the MINI Cooper S which is supercharged from the factory. It is less expensive to integrate a turbo into a car that has a factory supercharger than it is to remove the supercharger & fab up everything needed to do a turbo only setup. Not sure about other cars, but I know that the supercharger on the MINI actually keeps the turbo from getting to its full potential. So you get more horsepower deleting the supercharger & adding a turbo but it costs a lot more. I'm not sure how twincharging affects the power curve. It may give you the best of both worlds at the cost of some peak horspower.
Old Dec 20, 2007 | 06:05 PM
SSP-Ralliart's Avatar
There is really now reason at all to do that. You may get more power but your bottom end won't be able to take it. You have to run very low Psi on both which would suck. Unless you ran them sequential. Then it might work right.
Old Dec 20, 2007 | 11:59 PM
akinakin's Avatar
Hahn RaceCraft build a system for the Cobalt SS/SC that's called the ...er..."Twin-Charger" system, or something similar..that they introduced at the last SEMA show.
They claim the stock blower gives the car a strong bottom end and the turbo takes over on the top end and gives the car the best of both worlds.
Old Dec 21, 2007 | 12:03 AM
CaliMR's Avatar
i think it has been used successfully on diesels for a while, and i am pretty sure wv has one on a production gas engine
http://www.autoblog.com/2006/05/10/v...ngine-of-2006/
Old Dec 23, 2007 | 01:07 AM
Hydro420Evo's Avatar
have you guys seen a twin turbo and supercharger producing 1200 hp?
http://www.musclemustangfastfords.co...bra/index.html
Old Dec 23, 2007 | 04:12 AM
hmsevo9mr's Avatar
I never thought it was possible.
Old Dec 23, 2007 | 04:52 AM
FocusMSP's Avatar
Possible but you need some type of bypass as you make the switchover to turbo from the supercharger...
Old Dec 23, 2007 | 10:15 AM
Silverbolth's Avatar
^ not if your using a "roots-type" supercharger...
Ghilversumtuner
Lancer Aftermarket Forced Induction Tech
13
Jun 30, 2011 03:55 PM
Bryce89
44
Aug 1, 2008 10:07 AM
krnkimchi702
42
Apr 24, 2008 01:47 AM
Kaymo
283
May 3, 2005 10:23 AM
Striker_Thao
Lancer Engine Tech
37
May 3, 2004 02:06 PM
