O what fun...
Old Jan 6, 2008 | 04:35 PM
lanzerralliart's Avatar
EvoM Super Moderator
O what fun...
Ok , so after a short drive to the mall, I was parked and idling and then I noticed that the ac wasn't as cold as normal so as I'm tryin to figure that out my hood looks like the lid of a pressure cooker....I turned the car off and popped the hood and the top section of the radiator is cracked wide open.I wasn't beating on the car preivously or anything I'm really puzzled as to what happened...Anyone with some hints guesses etc. would be helpful I don't wanna replace the radiator just to have it happen again.
Old Jan 6, 2008 | 04:43 PM
SSP-Ralliart's Avatar
Well if the top section is cracked open then you can either have to repaired but considering that the top is plastic and the mid section alum. I would get a new one. Did your temp spike? Where was the guage? Also you may of had a blow out from either the thermastat not working properly or even the cap. I can't tell you for sure because i am not there. Hope this helps alittle.....I need pics to give good observation...
Old Jan 6, 2008 | 05:05 PM
I'm planning on replacing it, I had a little trouble finding a ralliart radiator ,I think I'm gonna use an OZ or and evo one ...looks like it will work clearance and connection wise...
Old Jan 7, 2008 | 09:43 AM
well to update I have to check and see if the head gasket is cracked ...I hope like hell it's not ....this really blows I was so close to getting some rims and tires then bamm...o well guess it could be worse...
Old Jan 7, 2008 | 09:47 AM
Mitsubeastin's Avatar
man that sucks dude. Im gonna send you another pm about nitrous on a ralli art I got some more questions to ask ya
Old Jan 7, 2008 | 11:55 AM
otter's Avatar
EvoM Administrator
Check to see if Evo radiators fit. If they do, you can probably find a cheap used one or go aftermarket.
As for why, my best guess would be a combination of corrosion and manufacturing defect.
Old Jan 7, 2008 | 12:09 PM
bruce988jl's Avatar
definitely looks like you got a bad one out of the batch that the corrosion, like otter said, took its toll on.
Geeze.. I wish I still have AC... I have a leak behind the dash somewhere, and on top of that its mad cold up here. Wanna trade houses for a bit?
Old Jan 7, 2008 | 12:26 PM
KreepaEvoX's Avatar
Get a Koyo for Evo, a friend has it on his RA, so lightweight and cooler that he only secured it with plastic straps....it has been holding up for its 3 rd year in a row
Old Jan 7, 2008 | 07:33 PM
found a stock evo 9 one for a good price it's going in tomorrow , I went and got a rental..mazda 3 , torqueless..it sux got to get my baby back on the road asap....
Old Jan 8, 2008 | 03:10 AM
joeyj's Avatar
my deepest sympathies to you
Old Jan 8, 2008 | 04:17 PM
ok so my fans went out thats why my radiator went...so now i got to get a fan assembly , I think, I have to do a bit of searching I think there is just a resistor or something of the sort that might be the problem , again any helpful insight would be much help I may have to sell something from my car to get the extra $ needed...
Old Jan 8, 2008 | 04:59 PM
ralliart 04 21's Avatar
here a couple of site for oem partsGenuine OEM Mitsubhsi Parts CatalogMitsubishi Online Parts .com - Genuine OEM Mitsubishi Parts at 25% off Retail.Discount Mitsubishi Parts - Genuine OEM Replacement i think you might find it here
Old Jan 9, 2008 | 07:23 AM
to keep this updated it was the fan controller not the fans that went , this sux a 30 dollar part has now cost me a radiator and 3 days having to drive a mazda 3 which really sux...
Old Jan 9, 2008 | 06:17 PM
car is back and hittin the track....see if i can better my times a bit...
