problem
Old Feb 27, 2008 | 08:41 PM
kulka's Avatar
mine stops doing this sound too... thats weird car haha
Old Feb 28, 2008 | 03:17 PM
hunt3rRA's Avatar
i thought mine had stopped to but it didn't. it just takes more force to get it to "pop" but it instead makes small "grinding(ish)" noises. take a ride with your radio off and windows and see what you hear. it probably didn't quit altogether.
Old Feb 28, 2008 | 05:20 PM
06silverRA's Avatar
I would go with otter and check your spring perch.
My car was making a nasty clunk when turning / hitting a bump almost like the wheel was going to fall off. Took it to the dealership and right away they knew what it was and showed me. If you stick your hand up in the fender where your front springs are and follow the spring down to where it sits, there will almost be a cup that nicely holds rocks. If you pull the rocks out of there you should see white impressions/scuffs on the rocks, which is causing the springs to not properly compress making a bad sound.
After I pulled out 2-3 decent sized rocks never had the problem since.
Old Feb 28, 2008 | 05:48 PM
hunt3rRA's Avatar
i'll do that after work. I must of missed Otter mentioning that. Or at least didn't realize thats what he meant. Thanks for the idea.
Old Feb 28, 2008 | 09:32 PM
Thomar's Avatar
I wanna comment on what 06silverRA mentioned...
The guy in the dealership i talked to said the exact same thing.. he also mentioned the rubber lip around the bottom of the strut. He says all ralliarts that come in with the same complaint he suggests for 50 bucks they'll cut the lip off and clean/wash away all the rocks, sand, etc.
Old Feb 28, 2008 | 09:39 PM
kulka's Avatar
nice knowing that guys....
yeah i once opened my window and while i was driving no matter what speed i heard constant ticking...
Old Feb 28, 2008 | 09:40 PM
Thomar's Avatar
^ rock in your tire? lol
Old Feb 29, 2008 | 05:09 AM
Kurt's Avatar
Does the ticking noise speed up and slow down as you accelerate or brake?
That is a good thought. I have had that before and it is big PITA.
Old Feb 29, 2008 | 05:34 AM
Lancer7's Avatar
My tires are too bald to hold rocks.
Old Feb 29, 2008 | 08:10 AM
hunt3rRA's Avatar
Yeah, if you have my problem the ticking shouldn't be constant. Could be rock in your tire or something is just stuck inside somewhere. Mine is still making that grinding noise whenever I turn the wheel to the right or weight gets pushed onto the spring/strut. I'm going to get it cleaned out on sunday and contact my Mitsubishi dealer/shop to see if they'll do that thing for $50 of cleaning and making that lip a clean flush cut.
Old Eagle
Dec 16, 2020 08:28 AM
sledge_0
Lancer Troubleshooting
Jul 23, 2017 09:15 AM
daved912
Outlander Sport
May 23, 2017 11:21 AM
nhsean69
Mar 11, 2010 06:26 AM
