Oil light + Rough idle
Old Jan 28, 2009 | 01:38 PM
Lancer7's Avatar
Originally Posted by Fifty
So I got an update from the dealership, in total they pulled 5 codes (4 codes relating to the o2 sensors). Both o2's need to be replaced (not sure how much those are) and one code was 2101. Does anyone know what that code is? Its related to the throttle body.
The O2 sensors probably do not need to be replaced. If you don't have a CAT, the rear O2 sensor just needs to be backed out of the airstream. There's threads on here that show how to do it using an anti-fouler.
Old Jan 28, 2009 | 06:44 PM
toortool's Avatar
sorry to hear. hope you get it figured out soon.
Old Jan 7, 2010 | 02:57 PM
thaphoneistappe's Avatar
same exact problem at 97K
im having the same issue with the oil light at low idle. (750rpms). But i have no SEL. Should i assume i have to do the same?
Old Jan 8, 2010 | 09:59 AM
RalliDew's Avatar
no dont assume anything. the dealership probably isn't exact right about the problem and they are on the basis of replace before testing solutions... there are two sensors on the car for it. one is on the block under the intake manifold. witch is the one for the light... and the other is on the tranny side of the head for the mivec control.. if the one on the head is bad it will idle funky like that. the one on the back of the block is only for the light and makes no difference if its there or not...,. i dont have mine in cause i have a oil pressure sender there.
Old Jan 28, 2010 | 02:46 PM
RAlli//ART305's Avatar
yea... what he said ^^ he is right about that..
bump..
Old Feb 12, 2010 | 10:28 AM
TheGreek's Avatar
I had a rough idle and the oil light would kick on after the engine warmed up.
I replaced the oil pressure switch, and it has been at fine ever since (last summer).
Old Feb 12, 2010 | 02:39 PM
lanzerralliart's Avatar
EvoM Super Moderator
So anymore info on this I have had my gt tb installed for awhile now and have had no problems ,just curious. Thanks
Dylroche
May 31, 2016 10:51 PM
hurdle18
Feb 23, 2015 07:26 AM
OPENA(671)
Sep 5, 2013 09:54 PM
arievox
Jun 20, 2013 02:46 PM
EvoAirRick
Apr 25, 2013 05:50 AM
