Fuel Issues?
Old Feb 26, 2009 | 06:20 PM
GearDownSon's Avatar
So have you put the car completely back to stock and see if that solves anything?
It would at least narrow it down for ya..
Old Feb 27, 2009 | 10:37 AM
Pin2Win's Avatar
Originally Posted by Lancer7
Huh? So the CAI isn't on your car, you have the stock one on?
Sorry, no I still have the CAI. To be honest I probably wont put the stocker back on cause its going to be a PIA. I am hopfully gonna get some free time tomorrow night or sunday to tear it down and look.
Has anybody ever thought that maybe just the injectors are clogged up bad? I know theres not a real great way to clean them, but im just thinking that might be the issue maybe?
Old Feb 27, 2009 | 01:49 PM
Canada_Comp's Avatar
i doubt you need to change it back to stock. just check for oil in the piping and MAF
as for the fuel injectors... check in the phone book. I know there's a place in my city who cleans and tests fuel injectors to make sure they are in spec. Highly doubt that the injectors are clogged though becuase there are fuel filters, plus i have over 80000 miles on my car and never had any problems with fuel injectors.
which fuel are you using? maybe try using a top-tier fuel
http://www.toptiergas.com/retailers.html
Old Feb 27, 2009 | 02:46 PM
You dont want to change your cai back to stock but you want to clean or change your injectors?
Old Feb 28, 2009 | 08:40 AM
Pin2Win's Avatar
Yea, well if they were to get cleaned or replaced someone else would do it. I have another idea I might try to tonight. I will post tomorrow if it works out.
Old Feb 28, 2009 | 09:51 PM
Pin2Win's Avatar
Well my idea was a no go because apparently our car has no fuel filter. I thought maybe it was clogged and causing my car to run back. I guess we have some strainer thing instead?
Also my SES went off tonight, so who knows maybe my car is demonized?
Old Feb 28, 2009 | 10:06 PM
wow.. we have no fuel filter?
and SES light going off as in going out, or turning on? (kinda confusing like "the alarm went off")
Old Mar 1, 2009 | 01:03 AM
It does have a fuel filter.
It is just attached to the fuel pump.
Old Mar 1, 2009 | 01:27 PM
Thomar's Avatar
it has a mesh screen for a fuel filter, i thought. but not actually a cartridge type filter.
Old Mar 1, 2009 | 07:23 PM
Pin2Win's Avatar
Yea thats what I was told it had. So I ran my buddies scanner on it today and it pulled P0171 which is lean Bank One and P0300 which is random misfire.
So we looked around and there is no real fix, my friend said that the (front 02 sensor?) was not reading that great, but the cost to replace one is like $160 or somthing so I will just let it go.
But I did clear the codes and pulled the negative off and kept it off for 2 hours (went to applebee's ) and came back let it idle for about 20 min (its cold here) and then drove it home not going over 3200 rpm. It drove good so who knows?
FASTER345
Mar 25, 2015 05:52 AM
JohnDoe1984
Nov 11, 2011 07:24 PM
journeymansteve
14
Jun 17, 2009 03:11 PM
JordanS4
28
Oct 6, 2008 03:45 AM
wiggle1r
May 6, 2005 07:05 PM
