HID issue
HID issue
im having a bit of an HID issue...my passenger side bulb keeps going out...it will flicker then sometimes completly go off...i also noticed that its dimmer than my driver side one...it usually comes back if i flick my brights on and off...im not sure if its the bulb or a short in the wires or ballast...i check all connections and there all good...so im stumped...maybe ill have to buy a new bulb...i know norcal lancer baught the brand HID kit....Norcal if you read this, have you had the same problems...
thnks
-jared
thnks
-jared
i had the same problem but i didnt have HIDs in. i ended up having to replace the "pigtail" because the wiring started to melt to the headlight bulb. the dealer wouldnt replace it under warrenty and wanted about 150-200 dollars to fix . so i just bought the part and replaced it myself for 10 dollars. dont know if thats any help just just giving you my experience.
im thinking its some of the wires, on my HID kit both headlights would shut off and i moved around the wires and the problem was at the harness connecter to the headlight bulb connector. I just had to put it at a spot to were it wouldnt get any movement.
my buddy had this same issue also with his kit. Some of these HID kits have crappy wiring jobs
hey heartgram, i think i had a similar problem. I needed to buy a new HID bulb, that fixed the problem... my burnt out bulb would work randomly, but then eventually it just died completely so i had to order some new ones immediately. If you got them from www.xenonlink.com they offer a warranty, but i think its a hassle to do. if you have the patience, then go for it. hope my input helps
