Grinding 4th Gear!!
Old Jun 20, 2009 | 08:02 PM
Hot_Carl's Avatar
Grinding 4th Gear!!
Hey guys, i noticed in my car, if im at a high rmp in 3rd, or i just rev it up to a high rpm and shift to 4th gear, my gears grind. I know how to drive stick, so its not lack of expirience. I push the clutch through the floor and no matter what it ALWAYS GRINDS.
I just bought my ralliart on november and i love it, only a few minor problems.
I am getting a control arm bushing replaced on monday, and i plan on asking the technicians about the problem, but im worried they will say something like "why would u be at that high of an RPM in third anyways?"
So if anyone has any ideas or has had a similar problem PLEASE HELP so i can mention it to them. Thanks in advance.
Old Jun 20, 2009 | 09:25 PM
thaphoneistappe's Avatar
its your synchro. mine does that from 2nd to 3rd. a lot of guys have had the same problem and someone usually says its a synchro. i guess its a costly repair. if i go over 5 grand with mine and dont hesitate before shifting, it grinds. push that clutch in just a moment longer and see if it stops. thats how i get around my problem.
Old Jun 20, 2009 | 09:57 PM
Hot_Carl's Avatar
i have a warranty on mine, so will they be able to see that it is off without having to go 70+ on the highway and shifting into 4th? like i said im afraid they will tell me "there are no roads that require you to go that fast so why does it matter blah blah"
Old Jun 20, 2009 | 10:07 PM
joeyj's Avatar
if there's something wrong with the clutch, and its under warranty, and you don't have any mods for them to blame it on, they should pretty much have to fix it. dont let them weasel and complain their way out of an obligation they have to fix your car.
Old Jun 20, 2009 | 10:58 PM
Hot_Carl's Avatar
only mod i have is a sri...i dont think that will void anything
but even to get this control arm bushing replaced it took me months upon months...
"we dont hear the noise u r taking about.." "it is an exhaust hanger"
they are trying so hard to keep dicking me over.
Old Jun 21, 2009 | 12:13 PM
Matt_Jagg7's Avatar
Does it mean the syncro is ruined, or can you just change the tranny fluid? amaine does the same from 2nd to 3rd in high RPM. If not the syncro, what else coulf it be?
Old Jun 21, 2009 | 08:57 PM
Mr.B's Avatar
Definately syncro, I've have been replaced and what a fight. odds are they will tell you the problem is between the seat and the pedals.
Old Jun 21, 2009 | 10:37 PM
joeyj's Avatar
throw the racism (or anti racism if you're white) card at them and make a scene so they do it lol
Old Jun 22, 2009 | 01:31 AM
Hot_Carl's Avatar
ok, i will tell them tomorrow. is a "syncro" the technical term for it?
Old Jun 22, 2009 | 05:49 AM
Thomar's Avatar
yea, synchro.
when you're shifting from 3rd to 4th, no matter what the rpm, what happens when you pause in neutral for a moment before shifting into 4th? does that help?
Old Jun 22, 2009 | 07:44 AM
Hot_Carl's Avatar
yes, it helps because the RPMs drop a little bit more, but pausing in neutral means ill get a slower time.
im taking it into the dealership in an hour..ill let u know what happens. wish me luck..
Old Jun 26, 2009 | 07:47 AM
thrashinator18's Avatar
try driving in reverse for 5 miles. that usually fixes any current problems im having.
Old Jun 26, 2009 | 08:03 PM
Thomar's Avatar
^ lol. where do you go to reverse for 5 miles?
Old Jun 26, 2009 | 10:15 PM
black ralliart's Avatar
Does this roll your odometer back 5 miles as well?
Old Jun 26, 2009 | 10:56 PM
joeyj's Avatar
only in ferris bueller's day off
