Auto Trans Flush. Thoughts?
Old Jul 18, 2009 | 08:36 PM
car852's Avatar
I'm thinkin about doin my automatic tranny fluid. I'm at about 56k right now.
I found the tech sheet for it
I guess our auto trannies need like 10 quarts. ugh. so thats about 50 bucks for the cheap ****, and as much as a 100 for some good stuff.
What do you automatic guys think? What have you guys used? I've searched around, and it seems theres all kinds of discussion on the M/T, but not much on out A/T.
I wonder how much the mechanic would charge for the tranny flush... Hmm.
Thoughts?
Old Jul 18, 2009 | 08:47 PM
Junkyard's Avatar
Two five gallon buckets, some extra cooler line, some fluid,and a lil time is all you need. Take the lines off of your trans cooler, find the in line and the out line. Hook them both up to about 3-4 feet of hose. Fill a CLEAN bucket with fresh fluid, run the in line to that bucket. Run the out line to another bucket. Have a friend start the car. When the fluid from the out line looks like the fluid from the clean bucket, shut it down, hook up your lines, fill to spec, done. Thats a trans flush. Better to get the filter and gasket kit, if available, and drop the pan, clean the magnet and pan, change the filter&gasket, and reinstall. Do this after the flush, since you will only remove about half of the fluid with the pan and gasket.
Old Jul 18, 2009 | 10:48 PM
car852's Avatar
haha thanks for the tips, junkyard. that helps a lot!
Old Jul 20, 2009 | 02:43 PM
car852's Avatar
Hmm. I talked to Jiffy Lube about flushing the automatic transmission in my car.
They quoted me 150 plus 20 off with a coupon i have.
Considering the fluid alone cost half that, I'm wondering whether or not I should just take it in, because really, I have nowhere to do this flush. I live in apartments. Maybe I'll save up a little and have them do it.
Old Jul 20, 2009 | 03:18 PM
otter's Avatar
EvoM Administrator
Check the service interval. IIRC, auto trans isn't due for a fluid change until you hit 100,000 miles.
Old Jul 20, 2009 | 04:04 PM
jve153's Avatar
hate to say it, but id almost take it into mitsu for the flush, prolly close in price to the jiffy lube and will be using factory fluids. just my .02.
Old Jul 20, 2009 | 08:13 PM
car852's Avatar
100k? hmm. maybe ill wait. i didnt think anything lasted longer than our iridium plugs.
Old Jul 21, 2009 | 03:10 AM
robyn402's Avatar
AT flush is due at 48000k(30000miles)/2 year service
i myself just had this debate to do it myself or have someone else do it
i bought 6 quarts(if you do it by hand without a flush machine you'll need 9 quarts) of the mitsu atf(as to keep it under warranty) and took it to the nearest quick fluid change place, might charge like $100 for the flush, and i opted for a flush additive similar to the engine flush cuz my AT fluid was pretty nasty
took like a half hour at the quick lube palce
Old Jul 22, 2009 | 11:12 AM
car852's Avatar
whichever it is 30,000 miles or 100,000 miles, i think i'm gonna get it done soon. it feels like its shifting hard. nowhere near as hard as a manual, but when you have an a/t, you can tell the difference from when you first got it.
Old Jul 22, 2009 | 12:06 PM
otter's Avatar
EvoM Administrator
Robyn is right, just looked it up. On the severe schedule, both transmissions get new fluid every 30k. Personally, I've never seen an auto trans that calls for new fluid that often.
Old Jul 22, 2009 | 09:57 PM
robyn402's Avatar
yea i put off my trans flush till 60000 kilometers(sp 41000 miles i think) and the fluid came out very black, was pretty gross actually, get 'er done.. mid as well toss in a transmission cooler, takes like a half hour to mount and tap the lines
Old Aug 2, 2009 | 06:58 PM
car852's Avatar
are there any specific tranny coolers that you fellow auto ralliart guys use?
Old Aug 2, 2009 | 09:26 PM
robyn402's Avatar
i just got one from local parts store, mister transmission brand cooler
Old Aug 20, 2009 | 06:22 PM
car852's Avatar
im gonna opt for buying the fluid myself and takin it down to speedee next door. i wanted to do a complete flush, but im low on funds at the moment. they're gonna charge me 40 bucks for a drain/refill if i bring the fluids.
the best quote i could find for just a drain/refill was 100 bucks (including the fluid) but if i get it from autozone the fluid comes out to only like 30 bucks or so.
junkboxEvo
Oct 18, 2015 03:23 PM
Shizzle
For Sale - Cars For Sale
10
Mar 19, 2014 02:42 PM
Stosskraft
Lancer Tranny/Drivetrain Tech
Jan 2, 2014 06:00 PM
car852
Feb 12, 2010 12:42 AM
