Depo headlight guys....
We were talking about that before about swapping the projectors but the only issue really is that the mounting holes dont match up with the housing so you're going to have to redrill the projector in order to be able to make it fit. I dont think you'll have to switch bulbs because the wiring is meant for h7 i believe? and the wires arent connected to the projector itself
i dont think the mounting of the new projector would be my biggest issue... i think it would be the wiring lmao i hate waring with a passion... even if you could fab up some kind of mounting plate somehow instead of drilling new holes in the projector....? i think it'd be a worthwhile venture...
: ripping a hand through the dirt : this thread is back from the dead ....
How do I adjust the projector ?? I have the same problem as stated above, where the left looks perfect but the right is pointed up in the trees , or palms as it may be. I removed that rubber piece and looked at it a bit but didn't really see a way to adjust it...
here is a layout of the types of cutoff styles:
The only way to get the D.O.T pattern or a custom straight line pattern is to create that cutoff sheild. I did on my projectors and they came out like this:
top one is ECE and bottom one is mine:
ECE cutoff:
My modded straight cutoff:
So if your looking for that straight line cutoff you need to customize your cutoff sheilds!
-Tony
And thanks Mitsu.kid.02 / Tony for the info. I at least feel better if I can't change this without the covers . That it's suppsed to be like this ..
Mine doesn't have abolt on the backside of the projector just 2 philips screws.. Your talking about removing the rubber cover and it's behind there right? Cause mine doesn't have it..
whiteout
Lancer Troubleshooting
May 6, 2013 10:10 AM
imalancerman
12
Nov 17, 2010 06:26 PM
