Where to purchase CV axle?
Old Jan 13, 2010 | 03:31 PM
Raikiri's Avatar
Originally Posted by Jabl3s
ts not just a cold start for me. its clicking at stop, clicking on turns, and clicking when pulling into a parking spot after over 30 minutes of driving.
does it happen when going in a straight line also? if so it may then be your wheel bearing or your cv joint if not both...
Old Jan 13, 2010 | 03:38 PM
Raikiri's Avatar
double post
Old Jan 14, 2010 | 06:28 AM
maxsideburn's Avatar
yes, my issue sounds similar to yours Jabl3s
I have some decent audio equipment, later I will try to get a recording of the sound and post it up here to verify it's the same you guys are hearing.
Old Jan 14, 2010 | 07:46 AM
here is a link to the sound file:
http://www.filedropper.com/test_32
listen closely. the louder noises are probably me hitting the microphone when I turned the steering wheel, but the CLICK CLICK CLICK CLICK CLICK is the noise I'm talking about.
Old Jan 14, 2010 | 01:40 PM
RalliDew's Avatar
Originally Posted by maxsideburn
Oh, and my question still hasn't been answered.
WHERE do you buy new CV halfshafts for these cars?
it used to be a problem for the normal auto parts stores to get ahold of remanded or nrew cv's for our cars but you can check you local autoparts store now and days, they have updated alot of stuff for our cars that they never had before.. i should say that have added more common parts for our cars... best to start there. they can also source junkyards they use for such items.
Old Jan 14, 2010 | 01:43 PM
RalliDew's Avatar
i think otter stated above it may be time for new strut bearings. if they seize up they will start to rotate the springs and youll get a type of clicking sound as well as pulling in the steering from a result of the springs being wound up by turning and still having load in them.. PITA. but and easy fix non the less.
Old Jan 15, 2010 | 06:25 AM
strut BEARING?? never have I heard of such a thing.
Old Jan 15, 2010 | 01:40 PM
RalliDew's Avatar
at the top of the shock assembly there is a diff type of bearing then im sure your used to but non the less still one and it can seize.
This bearing lets the spring rotate as you turn and not bind up.
Old Jan 16, 2010 | 06:59 PM
Jabl3s's Avatar
so what is exactly is the worst that can happen if i dont get my struts replaced... with all this clicking going on...
Old Jan 16, 2010 | 07:01 PM
Jabl3s's Avatar
i meant not getting them replaced sooner rather than later.. like waiting until april or may..?
Old Jan 16, 2010 | 07:10 PM
RalliDew's Avatar
i dont think we have confirmed that thats what the problem is( strut bearings), if it is though, not much can happen all its gonna do is affect your steering a bit. but no long term dmg would come from a few months like that. its not going to lock out your steering or anything like that it would just pull alot one way after you make a u-turn or somthing if tension gets stored from them being bineded up a bit but you can fix it by turning the other way until you hear the spring pop back to norm.
CV's can go a wile with a hole in the boots or kinda messed up they just need a bit of grease to keep them going. the only way those can fail is if the bearings inside the drive cups explode and come apart witch would not alow the power to be transferd in the drive cup. but once again no long term dmg unless you wreck or somthing but it wouldnt be anything violent just a horrible metal noise. and grease everywere.
find out what it really is first before you go buying parts. it could be somthing totaly different then what we have talked about.
Old Jan 17, 2010 | 11:17 AM
Jabl3s's Avatar
this whole spring being wound up and relieving tension and popping back into position description seems, and sounds, to be right on the money..
Old Jan 17, 2010 | 02:14 PM
Canada_Comp's Avatar
if it's clicking even when the vehicle is stopped, it might be your valve lash might have to be adjusted. make sure the sound isn't coming from the valve cover.
my clicking only happens when it is cold out and I think it has to do with my RRM LSD either having too much play in the planetary gears, or being assembled improperly.
Others of you may be getting the clicking from the regular diff not having the backlash within specs.
but the above cases only involve the vehicle when in motion
Other possible causes is the clutch bearing gone bad? drive belt tensioner going bad or other components of the drive belt making the noise? timing belt tensioner?
I can't access the sound file, so I can't say what it could be. but make sure it's coming from one area and not echoing off another.
Old Jan 17, 2010 | 02:16 PM
my coilovers used to do that.. they would go... *boing*boing*boing*boing* and after a big low speed turn the springs would be still somewhat wound in the direction of the turn, so it would pull a bit to that side
Old Jan 17, 2010 | 03:36 PM
RalliDew's Avatar
yep thats it
