Sticky temp knob?
Old May 12, 2010 | 02:48 PM
maxsideburn's Avatar
Sticky temp knob?
I read in another thread that someone else was getting this issue. My temp control knob is almost impossible to turn. Has a solution to it been found?
Old May 12, 2010 | 06:14 PM
otter's Avatar
EvoM Administrator
There's a solution but it's a pain in the *** (which is why I haven't fixed mine.) You have to completely remove the dash, remove the air plenum, take it apart, and replace the blend door.
https://www.evolutionm.net/forums/mi...hard-turn.html
Supposedly, the problem can be made less so just by replacing the gears, which can be done from the driver's footwell. I'll probably try that sometime before next winter.
Old May 12, 2010 | 08:07 PM
edbighead's Avatar
I just deal with it, like otter said it seems to be a hard fix.
Old May 12, 2010 | 08:21 PM
if i could find the part # for the gears i would do that part myself
Old May 13, 2010 | 01:30 AM
Myszkewicz's Avatar
I *think* the gears are PN# 7801A110.
Old May 13, 2010 | 07:14 AM
otter's Avatar
EvoM Administrator
The part numbers are in the link I posted.
