Nitrous question
Old Nov 25, 2010 | 08:40 AM
otter's Avatar
EvoM Administrator
Originally Posted by OttRalliart05
I cant remember where I heard this but there is a Country I think its Italy that you can not modify any car without the govt approval. That goes for wheels as well, if you want custom wheels and any other mod for that reason it has to be approved and once it is done you get card saying it is ok to have such mods.....i
That sounds like Sweden. From what I recall, they have the most strict automotive laws in the EU.
Old Nov 25, 2010 | 08:41 AM
RalliartN's Avatar
Ever since that fascist OPP chief Fantino convinced the fool Ontario politicians that immediate seizure of your car and $1000's in fines for 50 km/h over the highway limit with no explanations allowed would boost votes, they enacted it into law here. Now to throw fuel on the fire, the pursuit of making sensible car mods illegal just makes everyone with a backbone and a brain want to give Big Brother and his jackbooted thugs the finger by running nitrous etc. and taking our chances.
Now I feel better I think the comments about limiting horsepower mods to what your car's chassis and engine parts can safely cope with on the road is sage advice.
Old Nov 25, 2010 | 09:30 AM
OttRalliart05's Avatar
That could be but for some odd reason Italy is ringing in my head but you could be right.
Old Nov 25, 2010 | 01:25 PM
hackish's Avatar
The stats for deaths due to speeds 50km/h over the limit never did support it. I wouldn't worry about them outlawing car mods. It would close down an industry that makes millions each year. Business owners (voters) would not allow that to happen.
In many EU countries mods even as small as wheel upgrades have to be inspected and approved and added to the ownership.
-Michael
Old Nov 25, 2010 | 08:26 PM
kayouu's Avatar
I Have A nice fat bottle in my ralli art I have RRM SRI, Some exhaust mods, rrm underdrive pully. Runs great no problems.
Old Nov 26, 2010 | 10:39 AM
Shad123451's Avatar
i wanted to take this route as well when i had my ralliart. i think you should go for it and see how it turns out. let us know.
Old Nov 26, 2010 | 03:37 PM
deathsythe99's Avatar
Originally Posted by Jabl3s
He doesn't live in IL. I've asked
lol i do need to change that.
Old Nov 26, 2010 | 04:04 PM
i talked to the guy who sells/installs the kits he told me to start off small like 35-50 shot and work my way up. he told me for the nx kit with a 10lbs bottle install and dyno with wideband afr will be $1130 i dont think thats bad at all but id have to wait till tax time like i stated before.
Old Nov 27, 2010 | 04:26 AM
lanzerralliart's Avatar
EvoM Super Moderator
I guess that's an ok deal if he is installing it etc. But you could save yourself about 500+ bucks if you were willing to install it yourself. It's not hard , just time consuming. Mount bottle, run line to motor,disconnect battery, mount soleoids, install evo fuelrail, connect line from fuelrail to fuel solenoid ,nitrous to nitrous solenoid, mount relay , connect relay , run switches through firewall, mount switches, connect solenoids to power source, done. Fill the bottle and test her out.
But if you do get him to do it tell him to mount everything with mounted hangers (NO ZIP TIES) if has yo us a zip tie here or there tell him to show you where he did. Also do NOT cut the fuel line to skimp out of the evo rail. If you want a little cheaper tap the stocker. Like he said though , start off slow and work your way up, respect it and it will reward you.
Old Nov 27, 2010 | 01:21 PM
what evo fuel rail would i need? a stock rail of aftermarket? i dont think id trust myself to install the nitrous.
Old Nov 27, 2010 | 05:24 PM
Stock evo 8-9 fuelrail would work fine , aftermarket would be a waste of money. Stockers can be found for 20-30 bucks shipped in the evo section
Old Nov 27, 2010 | 07:38 PM
soulesswarrior's Avatar
The nitrous if you get a good kit is fairly easy to install. depending on what kit you use though could be an issue, the zex kit for example while the safest needs some things changed around to work right on our car
Old Nov 28, 2010 | 09:47 PM
kayouu's Avatar
K I'm curious what exactly you guys are talking about in changing the ZEX install. I have the Zex kit installed on my car, I could show you how to hook it up its so easy. I didn't get the Evo fuel rail myself I just did the inline splitter haven't had any issues, obviously it would be nicer to get the other F.Rail but it isn't mandatory.
Old Nov 29, 2010 | 02:24 AM
The fuelrail connection is mandatory if your wanting a larger shot. But I'd get it done just for simple peace of mind. You can either buy a used evo one or tap the stocker. Not doing so can be risky, you know how your not supposed to have cats around babies because the cat will put it's face right up next to the babies face and steal the air from it and eventually could kill the baby.... Well with your nitrous "T" your stealing the fuel needed to run the car, to run the nitrous which shouldn't be a big deal since the fuel pressure will try to keep up , but it's a game of cat and mouse. It's your car though do what you will.
Old Nov 29, 2010 | 08:17 AM
otter's Avatar
EvoM Administrator
What the **** is that crap?
Anyways, the rest of what he says is right, you *must* add fuel when using nitrous, otherwise you're just going to lean out the engine and melt/break things.
