Starting problem!
Old Dec 17, 2010 | 10:03 AM
nekkidlad's Avatar
no there is no sensor that says theres coolant in the oil, maybe u blew a fuse somewhere..?
u say u had fuel then not, reset the ecu and are gettign a battery and then u had fuel again after resetting the ecu..does it run again or not?
if u had the head shaved maybe its got just enough extra compression to not run right maybe?
ps if u can take it to a local parts store u can get it scanned for free, or depends where u go u can get a code reader for like $30 or less..even harbor freight has decent ones...it shoots u the code and sometimes a brief description on what it is..
Old Dec 17, 2010 | 09:48 PM
car852's Avatar
dangit! the car wont throw a code now so theres nothing to read. but the car still wont start.... im this close to pushing it down the street to speedy lube.
Old Dec 18, 2010 | 09:06 AM
Myszkewicz's Avatar
So start over from the beginning. Check again for fuel, spark, and compression. If those are all good, check your valve timing and ignition timing again.
Try to find someone local with a datalogger, who wouldn't mind coming over and recording a couple attempts to start. Then you could check various sensors and input/output signals to/from the ECU.
Old Dec 18, 2010 | 09:41 AM
soulesswarrior's Avatar
not in california. its now a law here that the auto stores CANNOT scan a customers car.
Old Dec 18, 2010 | 10:12 AM
lanzerralliart's Avatar
EvoM Super Moderator
That's some BS , I guess the mechanics weren't raping people enough...
Old Dec 18, 2010 | 10:24 AM
yup. luckily my gpa has one haha
Old Dec 19, 2010 | 10:57 AM
car852's Avatar
do you guys think i might have too much compression? does this sound like a possibility? i read about 160psi in all four cylinders.
Old Dec 19, 2010 | 11:07 AM
Myszkewicz's Avatar
160 is actually below the low limit. Should be 226, with 164 being the lowest acceptable reading.
You are checking compression with all four spark plugs out and throttle wide open, correct?
Old Dec 30, 2010 | 11:39 AM
car852's Avatar
hmm cant figure it out still. im gonna take it to speedy to have them run diagnostics. they can get it running for sure. itll be a little pricey. like 160 just for troubleshooting it, but they havent let me down yet.
ill let you guys know what it is after they troubleshoot it on monday.
thisll be good info for the ralliart archives lol.
Old Jan 5, 2011 | 10:28 AM
car852's Avatar
found the problem. there was sugar water in my tank.... who would put sugar water in a car thats not even running. only people that would have a reason to put sugar in my gas tank are the mexicans at my shop.
Old Jan 5, 2011 | 11:03 AM
Thomar's Avatar
Old Jan 5, 2011 | 11:08 AM
veloracer's Avatar
Well that's F'd up. Time to get a locking gas cap.
Old Jan 5, 2011 | 11:35 AM
car852's Avatar
maybe im just paranoid but they know where i live and they could very well have gotten a copy of the key, and since theres no alarm system... well.
do you guys know if theres a master key for those gas caps with the lock? i dont want ANYONE getting in there.
Old Jan 5, 2011 | 12:59 PM
Man that's some bs , I'd call immigration yo their homes and and their family and friends homes , odds are there's at least one illegal among them..
Old Jan 6, 2011 | 04:54 AM
nekkidlad's Avatar
really..?
sugar in the gas tank..?
damn...thats random...
i'd be PO'D if some1 did that to my car...
anyway hope u got it running better now hopefully all fixed..
as far as im aware there is no master key for the gas caps...unless you calll the manufacturer and im sure they would just sell you a new key for your specific cap...not send u some kind of master key..
