Attn Ralliartists :)
Pretty sure im going to have to pick a new controller up soon too. my fan has been staying on for about 10-15 seconds after the car turns off.
Part number i found for this is MR968246
does anybody know if that is correct?
Bux how much did you pay for a new one?
Thanks
Thanks
http://www.mitsubishiparts.net/cart/?pn=MR968246
Ouch those are spendy Yeah on My 04 it was like that when I turned the car on fans would turn on almost instantly. I swapped out both fans with my new ones and don't have the issue anymore.
Pics or DIY link
Does anyone have a DIY or pictures of this part, I'm unclear of the symptoms that you are experiencing, to have to replace this part. Thank you for your help.
I don't have pictures but if you look at the back of the radiator fan you'll see a black "box" with two plugs in it, one at the bottom and one on the side. That's the radiator fan control unit.
When it starts going bad, you'll notice that the radiator fan continues to run even after you've taken the keys out of the ignition, sometimes only for a few moments and other times for a good 10-20 seconds.
The car ends up running louder than it should because the radiator fan is either constantly running or struggling between turning on and off. Eventually it fails and your radiator fan isn't able to turn on, and some people have had overheating due to the fact that the fan never comes back on. I fortunately haven't but I have had to replace it twice, most recently in January.
