P0300, need some help
Old Mar 26, 2011 | 09:20 AM
Darewood's Avatar
Hey guys,
So the past week I've been doing some work on my car. My O2 sensor died so I had to replace it. While doing so I used one of those rrm catalytic code remover things on the other O2 sensor to get rid of my cat code. Then found out my car was running too lean from a hole in my exhaust . Got that fixed yesterday, but now a new code popped up after getting that fixed. The P0300- random/multiple cylinder misfire.
Could it be my spark plugs? I have the iridium NGK IX's in there now. Could it be that they got messed up or dirty from my car running lean? They're about 20k old and haven't had a problem.
Or is this code from something else?
Old Mar 26, 2011 | 10:51 PM
Myszkewicz's Avatar
From the service manual...
TROUBLESHOOTING HINTS (The most likely causes for this code to be set are: )
• Ignition system related part(s) failed.
• Poor crankshaft position sensor.
• Incorrect air/fuel ratio.
• Low compression pressure.
• Skipping of timing belt teeth.
• EGR system and EGR valve failed.
• ECM failed. <M/T>
• PCM failed. <A/T>
First thing I'd try is an ECU reset, which will make the car readjust the fuel trims. If the code returns, then I'd pull and check/replace the spark plugs.
Old Mar 29, 2011 | 05:28 AM
Darewood's Avatar
Hey thanks! I did actually do a reset when the weld was done but thats when the code popped up. Yesterday morning I looked underneath and saw more exhaust coming out, but in little holes So my mechanic doesn't know how to weld very well, but got it fixed again.
Looks like I'm 80 miles in and no CEL *knocks on wood* But I will look at my plugs if that code pops up again.
Chabada15
38
Oct 25, 2014 12:18 PM
ctfpevoVIII
29
Jun 5, 2013 07:34 AM
ryanholder24
Sep 20, 2011 02:57 PM
b00st3d.
Jun 20, 2010 08:49 AM
PHI_HO1
Jan 17, 2008 04:03 PM
