question about wiring of stereo
Old Mar 11, 2012 | 11:06 PM
nshen43's Avatar
Hi guys,
I'm going to replace the stereo of my 04 ralliart. I found the No. 3 and 9 on the harness are illumination and dimmer, respectively, but I don't have them for the new stereo. The new one just connects to the ignition 12V and battery 12V. How should I do for those two? Anyone got any idea about this? What about just leave them and connect the other 11? Thank you very much!
Old Mar 12, 2012 | 02:50 AM
CrAnSwIcK's Avatar
are you using an adapter harness? or just cutting wires?
Old Mar 12, 2012 | 09:12 AM
nshen43's Avatar
The new stereo has a different kind of harness. There are 13 wires: 8 for the spearks, 1 for ignition, 1 for battery, 1 for ground, 1 for antenna, and the last one is optional for an additional amplifier. What I'm going to do is unplug the wires from the original female harness and connect those wires to the corresponding ones on the new harness. Do you think this gonna work? Thank you very much
Old Mar 12, 2012 | 10:22 AM
roblaza's Avatar
You should have on the DECK side:
Speakers:
Green
Green/Black
White
White/black
Purple
Purple/Black
Grey
Grey/black
Red (12V Ignition/Switced)
Yellow (12V Constant)
Black (Ground)
Blue/White (Amp Signal Wire)
On The CAR side:
BUY THE PROPER HARNESS! lol If you get the proper harness for the car side, it'll plug into the OEM harness, then it's just a "match the colour's" game.
Old Mar 12, 2012 | 12:24 PM
nshen43's Avatar
Speakers:
Green
Green/Black
White
White/black
Purple
Purple/Black
Grey
Grey/black
Black (Ground)
On The CAR side:
Thank you very much! I've got all of them. Still two questions
1. What's the Amp signal wire for? I don't think I've got one.
2. Despite all of them, I have a pure blue wire. From the menu, this one should go to the power antenna. Did you include this as well?
Thanks a lot!
Old Mar 12, 2012 | 01:07 PM
roblaza's Avatar
The amp sign wire is one that send the signal to your amp when the deck is turned on to let your amp know to turn on.
If you don't have a blue/white, you can use the solid blue (power antenna wire) to do the same thing, as the lancers don't have power antennas. Run your remote site from the amp to the solid blue in the harness. Instead of powering up the antenna motor, it'll signal your amp to turn on.
Old Mar 12, 2012 | 01:31 PM
nshen43's Avatar
Smile
Got it. Thanks a lot~
Old Mar 12, 2012 | 02:07 PM
roblaza's Avatar
No problem. Sorry for the spelling errors, I'm on my phone so auto correct takes over
Old Mar 12, 2012 | 03:43 PM
CrAnSwIcK's Avatar
lol, if you don't connect the remote wire, doesn't the amp just stay on?
Old Mar 12, 2012 | 04:04 PM
roblaza's Avatar
No. It won't turn on if there's no signal to tell it to. If you run the remote wire to the power antenna wire, you're essentially doing to same thing the the blue/white accessory wore would to. When the deck turns on it'll send a 12v signal to the amp to tell it to turn on. Most amps need to see that 12 volts from both the main power wire AND the remote wire to turn on.
Old Mar 12, 2012 | 04:06 PM
roblaza's Avatar
And I didn't tell him not to hook it up, I told him to run the remote from the amp to the power antenna wire. Lol READ SLOWER MAN. Lol
Old Mar 12, 2012 | 06:48 PM
nshen43's Avatar
I've ordered a mail harness to make everything simple.
Old Mar 12, 2012 | 07:35 PM
CrAnSwIcK's Avatar
no, it was a serious question, i didn't know...just askin' jeeze...
LewisLancer
Lancer How Tos / Installations
Nov 17, 2016 09:42 AM
JukEboXAuDiO
Lancer Troubleshooting
Apr 23, 2014 08:43 AM
elecan
Evo X How Tos / Installations
Oct 10, 2013 02:08 PM
43%burnt
Jun 3, 2013 07:28 PM
sevensign
Nov 1, 2003 01:38 PM
