hood cable help
Old May 19, 2012 | 04:19 PM
deathsythe99's Avatar
Exclamation hood cable help
ok so i went to the track and tech asked me to open the hood and the cable snapped so now i cant open my hood. i called the dealership and they want $38 for the cable and 200 for the labor .....yea wtf?? so i was thinking to buy the cable and doing it myself but i have no idea where to start or how to do it can anyone help me?? i would rather do it sooner rather than later.
Old May 20, 2012 | 10:56 AM
Resurrected RA's Avatar
Work from under the car, behind the bumper. Feel for a spring on the backside of the hood catch, you will know what to do once you are there, it doesn't take much for the release. Un-install the busted cable and reverse the process for the installation of the new cable, it's easy.
The catch isn't installed on my car right now, I will take some pics that might help guide you...
Last edited by Resurrected RA; May 20, 2012 at 01:06 PM. Reason: You might not be able to reach it now that I'm thinking about it...
Old May 20, 2012 | 12:59 PM
ok well ill need to buy the cable and hopefully i can trace the cable back.
Old May 20, 2012 | 01:58 PM
ok well, you can also thank someone for trying to help you...just saying.
Old May 20, 2012 | 06:49 PM
but of course thanks for the info .
Old May 20, 2012 | 07:56 PM
Wow I was grumpy earlier, I was elbows deep in a Cummins Diesel for 2 days, I didn't get any sleep...finally got some sleep. My apologies for being a delta bravo.
I am going to get some pics of the latch so you have somewhat of a reference when you put your hand behind the catch. I will attempt to show you show you where the cable is running too.
Old May 20, 2012 | 10:04 PM
its alright i do it sometimes also but thanks for all the info that will definitely help me.
Old May 21, 2012 | 11:19 PM
Here is a picture of the backside of the catch. You can feel for the small spring and pull it in the direction of the arrow and the hood should pop-up, I checked the routing of the cable and it goes under the DS fender...I didn't investigate any further.
Old May 22, 2012 | 01:09 AM
Raikiri's Avatar
see if this helps at all
Old May 22, 2012 | 07:07 PM
thanks for the help guys i appreciate it alot i already got the cable on the way and will be here friday.
on the other hand idk whats wrong with the car it was 90 degrees today and i decided to drive it to the dealership and it was turning off and on within idk maybe half a second. the gauges and radio would shut off and on it only happens when its hot and i would loose power to the car for that half second i tryed turning it off to see if it would leave me stranded but it started right back up idk what the deal is ugh more problems
Old May 27, 2012 | 08:47 PM
ok i did this today not as hard as i thought and it works awesome thanks for the help
i ended up taking the old wire out and it was rusted :/ and thats why it broke.
Old May 27, 2012 | 10:11 PM
CrAnSwIcK's Avatar
good to hear...
make sure your battery terminals are good and snug...is it throwing a code?
Old May 28, 2012 | 07:09 AM
Originally Posted by CrAnSwIcK
good to hear...
its been throwing o2 sensor codes and the crankshaft sensor my negative terminal was loose a little bit so i just tightened that down today i think ill do a coolant flush sense its dirty and maybe the underhood bushings im gonna go to autozone as well and have them re-scan it for any new codes
Billy's MR
Feb 28, 2017 08:00 AM
Evo8MyMoney
Jun 2, 2016 05:49 PM
Evo Pete MTL
Lancer Engine Management / Tuning Forums
Nov 29, 2012 06:08 AM
wizzo 8
Nov 7, 2011 09:49 PM
Renyulb28
May 26, 2007 03:55 AM
