Another freaking problem
Old Jul 3, 2012 | 02:46 PM
JTCB's Avatar
So i bought my 2004 ralliart about a month ago and so far nothing but problems. First the fan problem had to change the fan module, next brakes started squeaking, now either the ToB or the ISB is making ALOT of noise and i think there might be something wrong with my suspension as it makes a tick noise when i hit bumps.
This morning when i drove off to work my car started fine. At lunch time started my car up drove to the store which is like a minute away and turned my car off and when i came out and got back in i tried to start my car and nothing no noise or anything tried many times, checked the connectors everything is good but the car wont start. Luckily my friend boosted me and i was able to drive home which is a 30 minute drive. When i turn my key 1 notch my volt meter goes up to like 12 and wabbles up and down and when i turn the key to ON everything goes dead.
Sorry guys kinda vented out a bit.
Thanks for the help
Old Jul 3, 2012 | 03:16 PM
RacerX-Ralliart's Avatar
Ill give you 500 for it
Old Jul 3, 2012 | 03:23 PM
JTCB's Avatar
Considering i paid 3gs for it and put almost 1g on it in the past 3 weeks lol i dont think itll be worth it :P but seriously any thoughts?
Old Jul 3, 2012 | 03:31 PM
There's a thread about the car not starting don't think anybody found the reason why.. If you keep turning the key or hold the key to the start position it'll start mine does.. it wont start at random times.. What I've tried that works and might be the problem is flipping the key over and trying mine fired up when I tried it but only tried it once. I did have a new key made but haven't tried it for to long to say its the key.. Is your key worn out? And check the battery post one member said his positive cable had corrosion and he cleaned it and had no problems.. As for the ticking there might just be rocks stuck under the spring another member posted a thread about a suspension sound but I don't think it was a ticking noise.. When you start out in first gear and full throttle it does it make a grinding noise but not in any of the other gears? If it does mine did the same thing and ended up being the ISB
Old Jul 3, 2012 | 03:53 PM
JTCB's Avatar
They key doesnt have anything to do with it because when i boost my car it starts no problem thinking mabey batterie is not holding its charge anymore or alternator is failing. The ticking doesnt sound like rocks more like a worn chock or spring i couldnt be sure. It makes a grinding noise in first and in 2nd and i also noticed when im pushing it to right before cutoff from first to 2nd it never goes in ive tested it 2 times in a row and all it did was grind and push it back felt so bad for my baby
Old Jul 3, 2012 | 04:26 PM
Just giving ideas of what could be the cause.. Go have the battery tested than.. Like I said before I'll give u 500 for it
Old Jul 4, 2012 | 02:57 PM
JTCB's Avatar
Ended up being dirty connectors cleaned them and she started no problem
phyzy
20
Feb 16, 2023 05:38 PM
wazzelby
Mar 29, 2017 06:28 AM
lghtngyello03
10
Jul 22, 2016 03:26 PM
213ralliart
18
Jan 18, 2014 10:16 AM
tougeFZ
Sep 3, 2010 01:16 PM
