blown motor?
Old Jul 24, 2012 | 11:09 PM
soulesswarrior's Avatar
blown motor?
Ok so I type this right now from my phone waiting for the tow truck. Was driving and out of nowhere start to hear a sound that sounds like a empty coke can rattling around my cup holder. But louder. This sound only happened during around 3500 rpm after about a min of that my car went into limp mode. While this was going on I did not see my temp gauge raise. Car then died and smoke everywhere. Any ideas?
Old Jul 24, 2012 | 11:12 PM
prowakeskater's Avatar
check your oil level. check your timing belt. check your balance belt. check your plugs.
my car made awful noises when the serp belt got chewed but yours is smoking which is worrying...
my bet is on the balance shaft belt. wait, do these have a balance belt? sorry i thought you drove an evo
Old Jul 24, 2012 | 11:18 PM
RoMeIX's Avatar
Good advice, I'd also recommend that you check your belts, that is the cause I suspect as well.
Old Jul 24, 2012 | 11:29 PM
Don't think its the belts and i only say that as the belts are about 20-30k doesn't mewn they coukdnt have popped though. And I checked oil while its not full its not drastically low. I also popped the rad cap to find almost no coolant which threw me off. Looked under car and the car is dripping coolant from tranny area yet i can't find any leaks up top. Though its dark as Hell and I'm still waiting for the tow truck. Sad face.
Old Jul 24, 2012 | 11:46 PM
Update. I dumped in more coolant prior to the truck arriving. When he began pulling the car onto the bed its started to bleed out the fresh coolant. From where i couodnt see.
Old Jul 25, 2012 | 03:35 AM
lanzerralliart's Avatar
EvoM Super Moderator
Sounds similar to when my radiator popped due to the fan controller failing.
Old Jul 25, 2012 | 04:52 AM
mikemike396's Avatar
I am so anxious to hear what the issue was! Hope all goes well!
Old Jul 25, 2012 | 07:21 AM
2006_RA's Avatar
Well coolant leaking could be good and bad. Good if it's a busted hose or even radiator. Easy but not necessarily cheap repair that the novice can perform.
Bad if it's that the cylinder head or block is now ventilated.
Good luck, remember sites like http://www.mypartshop.com/ are your friend.
Old Jul 25, 2012 | 10:22 AM
well after the car was on the towtruck heading down to my gpas house(had it send there, easier to work on there) i realized its most likely my coolant line for my heater core. had to do a bypass on them due to bad heater core and the line popped off once before but i caught it right then and there. so hopefully the overheat didnt kill anything in the motor.
Old Jul 26, 2012 | 04:47 PM
2006_RA's Avatar
Observation, analysis, diagnosis ????
Old Jul 26, 2012 | 06:01 PM
CrAnSwIcK's Avatar
how is she, Doc? will she make it?
Old Jul 26, 2012 | 07:30 PM
deathsythe99's Avatar
word how is she?? you got people on the edge of the seat
Old Jul 26, 2012 | 08:07 PM
biglou360's Avatar
wow hope it all goes well
Old Jul 27, 2012 | 12:42 AM
haha wont know much until saturday. i guess my dad tried to start it with no luck though
