Seized tensioner!
Old Sep 20, 2012 | 03:14 PM
JTCB's Avatar
Seized tensioner!
Went to the shop to go get my RRM UDP installed and the shop told me my tensioner was seized he tried with a big pry bar and nothing. They tried to look for one and had no luck i called my auto parts guy and he couldn't find one either can anyone give me the serial for it or is there anything that can be done with the one i have now.
Old Sep 20, 2012 | 09:00 PM
CrAnSwIcK's Avatar
it's hard to imagine it's seized...MN149179 is the part number. about $100 USD on mitsubishiparts.net, you might find one cheaper if you google the part number...
it's pretty stiff. but even if it was seized, i would think a large breaker bar would at least get it off, cause a large breaker bar, and some muscle could probably break the metal, pretty sure it's just cast aluminum..
Old Sep 20, 2012 | 10:54 PM
Raikiri's Avatar
idk. mine was seized before too i think. thats why i just replaced it with an entirely new tensioner.
Old Sep 20, 2012 | 11:07 PM
CrAnSwIcK's Avatar
can't you just lube it?
Old Sep 20, 2012 | 11:23 PM
Raikiri's Avatar
while it was still installed i coudln't really get the lube in there. my car is already at 135k miles anyway so i figured a new tensioner woudln't hurt
Old Sep 21, 2012 | 12:08 AM
CrAnSwIcK's Avatar
that's a lot of miles...good on you, man
Old Sep 21, 2012 | 04:35 AM
06_RALLI///ART's Avatar
NAPA has em for $150ish... But yeah I find it hard to believe its siezed
Old Sep 21, 2012 | 05:44 AM
04mralliart's Avatar
I installed an rrm udp kit last night n it took me 3 hrs should have taken 40 mins if my tensioner didnt give me problems I sprayed the **** outta it wit wd40 n tooj a 2 ft custom made breaker bar attached to the 1/2" drive it took some grrr.but it went. Maybe try a torch under neath it n a breaker bar. Ill check back later good luck
Old Sep 21, 2012 | 06:58 AM
lanzerralliart's Avatar
EvoM Super Moderator
Damn 150 for a new one ,an I just gave an extra one to a friend a while back for free. I thought they were cheaper.
Old Sep 21, 2012 | 01:28 PM
Talking
thats what friends are for..... what else u got laying around playing hahaa but no really hahaha
Old Sep 21, 2012 | 01:46 PM
JTCB's Avatar
Thats what the guy told me. Ill try another shop worst case ill have to get a new one but thanks for the info guys.
Old Sep 21, 2012 | 04:12 PM
So you haven't checked yourself?... Its easy to get at. I wouldn't waste the money at a shop.
Old Sep 24, 2012 | 09:25 AM
mikemike396's Avatar
lol fail:P Good friend you are!
Old Sep 28, 2012 | 06:41 PM
Myszkewicz's Avatar
It's the road salt that gets in there and seizes them up.
Mine was seized about four years ago. I noticed it when I changed the accessory belt. My big breaker bar only broke the square drive hole off, so I ended up removing the tensioner, hammering it apart, cleaning it, greasing the heck out of it, and putting it back on with help from a chain wrench. I finally replaced it two and a half years ago, when I did the timing belts.
newbieEVO8
Feb 29, 2016 03:26 PM
Swedin
Aug 21, 2013 10:47 AM
mkhalid
11
Aug 15, 2013 09:51 PM
jdm4g63tgalant
Apr 2, 2005 12:37 PM
