Need help finding a part # ... lost my manual -_-
Old Oct 16, 2012 | 11:20 AM
quikkstylez's Avatar
Hey guys. Took my RA to the shop the other day to have some work done and they told me my front crossmember was cracked
If anyone has access to the repair manual, or knows where to find the part # for it, please let me know. I know its an easy fix, I just need the part
Also, i've seen some lightweight and custom crossmembers for the evo guys out there. I know our front motor mounts are interchangeable, but are our front crossmembers the same as well?
Thanks in advance for all the help
Old Oct 16, 2012 | 11:36 AM
2006_RA's Avatar
Which cross member do you mean, 1 or 2 ?
http://www.oemmitsubishiparts.com/pa...agramCallOut=1
Old Oct 16, 2012 | 11:49 AM
#2 I believe, thanks man. Are those both "crossmembers" what is the name for both #1 and #2?
Old Oct 16, 2012 | 04:46 PM
CrAnSwIcK's Avatar
one is the main cross-member, hold the steering rack, lower control arms, rear mount etc. the other is the transmission cross-member and only holds the front mount...and can take between 10-30 minutes to replace...
Old Oct 16, 2012 | 09:52 PM
Gotcha. Thanks Crans!
I've been under there before to replace the front mount and it doesn't look like too hard of a job.
Can anyone still help me with a part #?
Old Oct 16, 2012 | 11:49 PM
CrAnSwIcK's Avatar
you're buying new?
Old Oct 17, 2012 | 05:11 AM
you're buying new?
Not necessarily. A part # would help in the search though. All I can find are Evo crossmembers. Do you know if the two crossmembers are interchangeable by any chance?
Old Oct 17, 2012 | 08:41 AM
CrAnSwIcK's Avatar
i'm not sure...
MR554735
Old Oct 18, 2012 | 05:34 AM
2006_RA's Avatar
It's the same on Lancers ES, OZ Rally, Ralliart and Wagon from 2002-2006. No mention of the Evolution, so I would think the Evolution has a different part.
Old Oct 18, 2012 | 09:59 AM
you guys are KINGS!
Thanks a ton for the help gents
doncarbone
18
Apr 14, 2014 12:05 AM
luckybull
Sep 19, 2013 12:19 PM
morgeesplease
Jun 22, 2013 07:47 AM
ClaudioEvoX
Sep 26, 2012 11:47 AM
