SES question
Old Oct 17, 2012 | 08:52 PM
tomcoulam's Avatar
SES question
On my way to work today, while in traffic, my car died on take off. I thought it was odd and thought I must have just not had the clutch engaged enough(don't know when the last time i stalled was). I restart my car and have very little power and my SES light is now on. I limp off the road into a parking lot. No odd noises, smells or leaks of any kind. About 30 minutes go by and I restart my car and the light is no longer on and my car acts like nothing ever happened.
Is something near failure? What should I look for/onto?
Old Oct 18, 2012 | 05:20 AM
bakuro117's Avatar
You never got a CEL? If so that would be really helpful in figuring out what happened.
My car has done something similar during a few different scenarios so its kind of hard to say without some feedback from the computer.
You said the car had little power, and you limped off the road. Im assuming this means the car was in limp mode?
Old Oct 18, 2012 | 07:40 AM
CrAnSwIcK's Avatar
limp mode for sure...check battery terminals and make a mental note, without a code, you'll never know...
Old Oct 18, 2012 | 07:50 AM
tomcoulam's Avatar
no cel light
battery terminals appear fine, no corrosion either
Posted from Evolutionm.net App for Android
Old Oct 18, 2012 | 07:57 AM
tomcoulam's Avatar
during the time the car was off i looked around the engine bay for signs of problems. i wiggled vaccum lines and the air box and also checked fluid levels. everything seemed fine, but i did have my suspension done last friday and maybe something was bumped loose? i have no clue.
Old Oct 18, 2012 | 09:09 AM
CrAnSwIcK's Avatar
are the battery terminals loose at all? check all your grounding wires as well...if a sesnor failed or the output was out of range, you would have a code...there may even be a pending code, where the ECU detected an error, but it takes more than one instance of the error to trigger the light...
Old Oct 18, 2012 | 10:02 AM
nekkidlad's Avatar
if ti were me...i'd get codes pulled...
depending if/what code(s) you find i'd ignore it untill it happened again...(so let us know if/what codes u find, if u get any pulled)
double check your terminal cables at the battery...since my bought the car(~3.5 yrs ago) i thought mine were fine and tight and i went to disconnect the battery one time(about a year ago), and realized the negative terminal was tight and ok, wich they were....only enough till u gave it a good wiggle and it would pop right off the battery...(so i put a new terminal on when i replaced the battery...)
Old Oct 20, 2012 | 11:20 PM
biglou360's Avatar
it is very strange the way these cars behave sometimes
fandadar
Jun 29, 2014 07:32 AM
vito93
Dec 24, 2013 07:47 AM
Mellon Racing
41
May 6, 2013 03:20 AM
manthny18
Dec 14, 2012 04:53 PM
Sir_Lancelot
Nov 7, 2012 09:36 PM
