OBX Header & DP
OBX Header & DP
Just received my OBX Header& DP combo!!
Alright so I recently heard my car from a recording my friend did and never realized how raspy my car was and am not really liking it... This is a recording of my friend scion tc 2011 with descendant exhaust and me with my magnaflow muffler and without a CAT
This is one from inside the car. Not pushing it to hard.. it was snowing like crazy.
You can also hear my bad wheel bearing its really annoying.
http://www.youtube.com/ watch?v=cwHk-sXj2ts
As soon as this gets done ill post a new sound clip for you guys!!
Nice header/downpipe combo
Nice videos but anything not at the track/sanctioned event isn't allowed here. I know it seems like I'm picking on you, but that's not the way of it, I assure you it's just the rules.
Alright but it was not sanctioned I wasn't breaking any speeding laws I went up to like 85 in a 90 zone!
Update for those reading, I'm bringing my car to the shop tomorrow to install my Header & DP cant wait for it to be done. Will try to post a video tomorrow night of how it sounds
Obx header question to those who own them
To does that own the OBX header do they make a ticking sound under load. Mine makes a pretty bad one.. Read somewhere that all headers make a ticking sound because the inner wall is thinner? Can anyone clear this up for me ?
Thanks
Thanks
Exhaust leak??
So recently after installing my OBX Header and DP I hear a weird ticking sound under load. I recorded it and its been so hard to get it online finally this is the only way i can share my mp3 click download file and download should pop up right away
BETTER LINKS!
https://soundcloud.com/justin-206/20130311-175752
https://soundcloud.com/justin-206/20130314-183412
http://www.wikiupload.com/KA6CH3TRATMBA8I
http://www.wikiupload.com/J1L4824RW7NS9CM
You guys should be able to hear the ticking sound im referring to. Does it sound like an exhaust leak cuz the guy who installed the combo told me he checked and there was no leak or does it sound like a normal header tick?
BETTER LINKS!
Two likely scenarios:
1. Noise from the engine valves are more pronounced due to that specific noise bouncing off the thinner piping of the OBX manifold.
2. Exhaust Leak - I would recommend you purchase better gaskets from Vibrant. Those OBX gaskets are worse at sealing than the O-ring that comes in the OEM CMC.
I didn't think anyone was really following this so I didnt post pictures.
https://www.evolutionm.net/forums/04...s-problem.html
2. Im gona look into the new gaskets. Just spent like 2gs fixing **** and now ive got another wheel bearing to change, this stupid header tick, valve cover leak..(mabey the cause of the tick)?? and pretty sure i need a new engine mount i have this weird bird chirp like noise a little on idle, when letting off the clutch (when the engine shakes), and on bumps...
The sound of the wheel bearing the ticking and the "engine mount" is driving me crazy
Thanks this was actually needed!!!
1. I heard this as well but ive asked around to other people who had the obx header and noone is experiancing this except for....
Ah man that sucks. And my bad it looked a little dark there on that corner could be a shadow from the picture though. The red bolts look really nice, I might have to try that. I had one of the bolts that holds the coil pack cover down break off while driving. I guess I tightened it up a bit too much and the vibrations popped it off. It sucks... :-/
The headers look really good in there, are you going to be heat wrapping them once you fix your exhaust leak? It may actually help the tick a little if it really is the sound of the valves like RalliartizeIt says.
