maf sensor advice
I'm not sure, I purchased it thinking it would fit a 4g64
I already have that on right now it's actually broken or something cause when I plug it in car starts to die out. I'm hoping to be able to fit something cheaper than the 605.... cause around here it cost roughly $700.
Now I'm quite confused about everything... my ralliart has a 4g93 engine...does my car come from the dealer with this engine... or do all ralliart have a 4g94..
Cause all I can find is that the 4G93 is mostly available on ozs.... is there any way to be sure...m cause my dealer says I have a ralliart so I'm sure it is... this is very confusing I just purchased a we bunch of things thing I had a 4g94 engine
Do u guys think that ignition coils spark plug wires and gaskets of a 4g94 would still fit a 4g93.... sorry I'm just freaking cause I ordered all this online..now I'm not sure if I should return them or not....and will the buyers except..God this is frustrating
Sounds like your dealership doesn't even know what car they're selling. You probably have an OZ.
EDIT: actually idk... not sure what they used in the non-usdm markets :/
no i dont think dealercwould know.... here they just do there job and not more. is there anyway o be sure about which engine i got...
p.s. when i checked for the diatemeter of my throttle body so i can purchase a respected silicone to connect the intake with... the opening was 70mm... does a 4g93 cone that way.... maybe i measured it wrong...
do you know the displacement of the motor? what year is the car?
4g94 - 2.0L SOHC (USDM ES,LS, OZ rally 02-07)
4G64 - 2.4L SOHC/DOHC (SOHC version used in USDM 3g eclipse gs 00-05)
4G93 - 1.8L SOHC/DOHC (sometimes turbo, not used in north american cars)
4G69 - 2.4L SOHC MIVEC (USDM Ralliart 04-06)
4g94 and 4g93 are very similar, and the SOHC versions only differ in displacement. so you have a 2.0L.
if you need assistance with your motor, consult with the 02-06 ES, LS, OZ Rally guys. However, I also own a 4G94 powered Lancer, can you pull a proper DTC?
Cool thanks for the tip but what's a DTC?
