oil pan
Old Feb 23, 2015 | 03:03 PM
gui dube987's Avatar
oil pan
Hello i plan on doing a little skid plate for my oil pan because i wanna protect it cause ill drop the car even more this summer..
So is the oil pan made of metal so i could directly weld the skid plate on it or it is not made of metal?
Old Feb 23, 2015 | 04:26 PM
CrAnSwIcK's Avatar
it's stamped steel...
Old Feb 24, 2015 | 04:26 AM
Ok so probably not the best material to weld on?
Old Feb 24, 2015 | 01:12 PM
CrAnSwIcK's Avatar
you should be able to weld it no problem...
Old Feb 24, 2015 | 05:00 PM
Sorry i speak french so i thought stamped steel wasn't a great material to weld on, well thats a great news, i might do a skid plate now
Old Feb 25, 2015 | 03:59 AM
CrAnSwIcK's Avatar
stamped steel is just sheet steel that's been pressed into its shape...
Old Feb 25, 2015 | 07:08 AM
bakuro117's Avatar
Yea it should be perfectly fine to weld on. Are you doing this yourself or having it done somewhere? The Evo oil pans have a skid plate welded on to their oil pan. Not a very thick one, but its obviously there.
Old Feb 25, 2015 | 08:19 AM
I'll probably do it myself, cut a piece of steel not very thick drill some holes in it so ill be able to weld the skid plate from there instead of welding only around it, just to be sure it will stay there
redlinedrift
28
Nov 11, 2011 03:16 PM
er0e
Apr 26, 2011 10:10 PM
downshift411
May 30, 2008 09:54 AM
