Some few drops in spark plug cavity
Old Jan 24, 2016 | 02:48 PM
kouroshb26's Avatar
So as I was trying to change out my spark plugs, I saw some few drops of oil on the spark plugs/ ignition coil.
Do you guys think that there could be a problem with a head gasket.
If so, how should I go about fixing it. Is it an easy job.
Thanks
Old Jan 24, 2016 | 07:28 PM
CrAnSwIcK's Avatar
if it's in the coils, it's just your spark plug tube seals...they're like $10 for 4. get a new valve cover seal too though, wet them with a tiny bit of oil and bolt the valve cover back on, do not over torque, the head is aluminum, and you'd likely pull the threads out of it before you snap even an M8 bolt...if your head gasket was bad, your motor would likely be running like ****, and you'd have oil in your coolant, and coolant in your oil...if you check your oil and it looks normal then it's probably fine.
Magrud3r
Sep 25, 2014 06:22 PM
AWDBus
Dec 8, 2011 11:01 PM
QAT-R
Aug 31, 2006 11:05 PM
majestic lancer
Mar 21, 2004 05:36 PM
DRC Imports
19
Nov 28, 2003 05:14 AM
