Possible to change the gauge cluster LED color?
Old May 2, 2004 | 12:51 PM
Hellacious's Avatar
yea, now all we need is someone to make the face plates for us
unless you just want all blue, then i think that would just be a matter of changing the bulbs, and removing the current face, or just painting the current face blue...
Old May 2, 2004 | 09:08 PM
WoRkZ's Avatar
Originally Posted by Hellacious
heres some chops i did of my gauges in my 02 OZ....
Endless possibilities really...
Interesting mod for an RA too (I don't think I like my red cluster that much)...
Damn, the list keeps getting longer! I'll still be working on that Lancer 5 years from now!!!
_
Old May 3, 2004 | 07:38 AM
pinoynoskillz's Avatar
how do u change the bulbs by on the stereo recievers? i want them RED! >.< where can i get these bulbs?
Old May 3, 2004 | 08:16 AM
WoRkZ's Avatar
Exclamation
That's a completely different undertaking... if you are not familiar with electronics maintenance, I'd advise against trying this out.
As per my experience with those things:
To change the unit's illumination color, you normally have to open the whole thing, remove the existing illumination LED (LEDs) and install (solder in) a new LED (LEDs) of the chosen color. Nowadays, most illumination LEDs are soldered directly on the PC-board of the unit (no standalone LEDs). So by removing and re-soldering directly on the board, you run the chance of burning the auxiliary PC-board up to the point where it will short-circuit another trace or cut some important traces.
This intervention should also void any kind of waranty you might still have on the unit.
Can anybody confirm this procedure for the Lancer unit though?
Now, as a (much more simple and secure) backup plan:
In certain instances, you might be able to simply open the unit and place some tinted material between the LED (LEDs) and the display. A satisfying result may be obtained for some colors, but would not be helpful in other cases.
In the example given, the blue tint might be turned to red by trying different red and/or orange filters. The resulting illumination will ALWAYS be less powerfull than the original setup, but it might suit some owners...
Good luck in trying this out. If you do, please let us know how it turned out...
_
Old May 3, 2004 | 12:18 PM
hmmm... will try it. pray i dont blow anything up.. =D
Old Apr 26, 2011 | 05:03 PM
blazianboii's Avatar
how did you do that with the led's? i have a 2002 ls lancer..
Old Apr 26, 2011 | 05:19 PM
lanzerralliart's Avatar
EvoM Super Moderator
Please refer to the search button. And look at the DATE before posting because you just bumped a 7 year old thread.....
Earl Needham
08+ Lancer Show / Shine
Jan 19, 2017 08:11 AM
Speedbird
AWD Lancer (2012 +)
Jan 1, 2016 09:24 AM
CottageLifer
Outlander Sport
Nov 10, 2015 05:59 AM
Turvo
Aug 20, 2010 07:05 AM
Roctght
Jun 28, 2007 12:28 PM
