The 2.4 MIVEC is a interference engine.....right?
Old May 7, 2004 | 11:33 AM
quantum's Avatar
I'm just wondering if the 2.4 mivec in our ralliarts is a interference engine. I assume so, but I may be wrong and that is why I'm asking. Given the choice I would perfer non interference, but I'm probably dreaming. So does anyone know for sure?
Old May 7, 2004 | 02:28 PM
WoRkZ's Avatar
Question
What the hell can an interference engine be?!?!?!?
Well, I sure as hell will keep an eye on this thread... It looks like I'm gonna learn something today!
Old May 7, 2004 | 02:34 PM
Tristar's Avatar
Interference / non-interference:
Basically its how far the valves are from the pistons. Basically the difference comes into play when a timing belt breaks. On a non-interference design, there is enough clearance between the pistons and valves to prevent damaging contact. An interference design does not have sufficient clearance between those parts and engine damage would result from a broken timing belt.
Old May 7, 2004 | 02:36 PM
Guack007's Avatar
Thnx. I learned something new today as well
Old May 7, 2004 | 02:50 PM
mitsumichael7's Avatar
FYI, the 4G69 is an intereference engine, just as the rest of the 4G motors are. (I am pretty sure they are, MIGHT be wrong but dont think so.)
Old May 7, 2004 | 07:19 PM
MitsuRalliArt's Avatar
The 4G69 is a small bore, long stoke design. Small bore engines are interference 99% of the time because there is very little area for the valves. Engineers try to compensate for this with longer lift on the valves.
BTW, it has a chain for the cams, not a belt. Belts will slip, a chain will not. Any slip on the cams could result in a valve meeting a piston.
Also, interference engines perform better.
The only advantage a non-interference engine has is high revs. I don't feel like doing a write-up, but trust me. At 12,000+ rpms, it helps.
Old May 7, 2004 | 08:54 PM
WoRkZ's Avatar
Talking
Damn good stuff man! Thanks for the info!
Old May 11, 2004 | 10:53 AM
quantum's Avatar
Yeah, I thought it was, but I just wanted to make sure. I'm use to non-interference engines, but oh well. Good explinations on interference and non-interference; I should have explained when I posted originally. Thanks.
Old May 12, 2004 | 09:34 PM
MitsuJoe's Avatar
My understanding of this is that the DOHC being interference would cause the valves to be in a bad place on part of the engine if the belt was to snap.
Although sense the RA is a SOHC then this is not a problem. If the belt goes the pistons won't "interfere" with the valves.
Anybody correct m e if I'm wrong, but this was my understanding of this. The 1.8 engine in the 90-94 Eclipses was not interference because it was SOHC, although it had a close area between the valves and pistons.
Old May 13, 2004 | 06:27 AM
quantum's Avatar
What we really need here is some good engine specs. I'm assuming that the piston crowns flat with the block at tdc; so if someone knows if we have flat top pistons or valve reliefs and as had the head off the car we could know. If the valves fully opened don't contact the top of the piston at tdc were all set. I have seen a few engines that did this where the fully opened valves just missed the valve relifes. Anyway; were not gong to know until someone gets good specs or takes one of or engines apart and looks. On another note: Wouldn't it be kinda cool if when the lower rpm cam ratio is in effect the engines not interference and then when the mivec kicks in it becomes interference......it's certianly possable.
Old May 13, 2004 | 10:02 AM
MitsuJoe's Avatar
I don't think that would be possible because the stroke of the piston is the same.
if your doing 2500RPM or 6500RPM the piston still has the same travel.
Old May 13, 2004 | 10:34 AM
quantum's Avatar
Thats true; but the idea behind the MIVEC engine is that once over 3500 rpms the valves open further and the timeing is advanced (or at least thats how I think it works). So under that rpm the valves might have enough clearence because they don't open as far as when the mivec kicks in. All of this is speculiavive of course; but I still tink it's possable.
Old May 13, 2004 | 04:42 PM
psy-q's Avatar
off-topic. Does the 4G94 also have a timing chain instead of a belt?
Ummm, I think that the MIVEC control on the valves is more in control of the duration of time the valve remains open that how far it opens. I MIGHT be wrong, but the valves dont open any further under MIVEC, just stay open longer under MIVEC. That and MIVEC has 2 hit points, not just 3500ish RPM, there is supposed to be another point somwhere in the 5000's.
Old May 13, 2004 | 04:46 PM
MitsuJoe's Avatar
There are 3 lobes to keep the cams singing all the way to redline.
I will check to see if this actually has a rubber belt.
