RE: Removing heat shield on header
Subscribe
Jul 9, 2004 | 10:41 AM
  #31
I am only guessing @ this, but I think the design was to catch some air from under the car and funnel it between the heat sheilds and the manifold/header to help catch some of the hot air and push it out the back. If I remember correctly I could put a finger on the heat shield for a sec also right after driving it when it still had the black coating on it.
Reply 0
Jul 9, 2004 | 11:43 AM
  #32
the heat sheild is there so that you do not make physical contact with the header, because it is so hot.
Reply 0
Jul 11, 2004 | 08:29 PM
  #33
Jet Hot Coat will be int only coating you can do to your headers to make a significant differenct in the underhood temps.
Reply 0
Jul 12, 2004 | 10:41 AM
  #34
FYI: The Heatshield temps out @ 225-250 deg, the area underneath is over 500deg as it is puts my temp gun out of range. Measuring right at the flange it is between 350-400 deg.
Reply 0
Subscribe
