Installtion Sri
Installtion Sri
do anyone have the step by step instruction sorry im new is it hard to install because i see u have to take off the censor do u have to reset the battery after u install it thank you im getting hte short ram intake from road race
diconnect the battery before you install the SRI, and reconnect the battery after you done with the installation. I will let the engine run for 15 mins and it should be fine then.
I installed it and i didnt disconnect the battery. Just unscrewed the censor and took everything that need to come out off and installed the intake, screwed the censor back in and everything worked perfectly. No need to reset anything.
there is a purpose of unplugging the battery. it reset the ECU and tells it that there is more air coming into the the motor and it will then adjust the settings for the air fule mixture. trust me, unplugg the battery and you notice
Mcstikman
Mar 17, 2024 09:51 AM
canyonkid
42
Sep 25, 2015 09:27 PM
sndm
04-06 Lancer Ralliart How To Requests / Questions / Tips
Aug 21, 2006 10:08 AM
