Quick ? Bout wideband n oil press gauges?
Old Apr 16, 2011 | 03:45 AM
rooney08's Avatar
I would like 2 know if these 2 gauges need 2 b installed by a shop, or can someone with the basic knowledge on electronics can do it? When u buy them new do they come with step by step instructions? Tnx a lot in advance for the Input...
Old Apr 16, 2011 | 05:39 AM
_______'s Avatar
give it a try!
You will need your local muffler shop to weld a bung for your eideband, but everything else can be done fairly easily.
The instructions will not be vehicle specific, but there are dozens of threads on here to assist with both.
Have fun!
Old Apr 16, 2011 | 07:06 AM
ReaperX's Avatar
Check the how to section, very helpful. Basic wiring knowledge is all you need to get the job done. Easiest way to me to wire them up for power would be using an add-a-circuit and daisy chain them together.
Old Apr 16, 2011 | 07:17 AM
spooldursti's Avatar
Like stated above, the wideband will need to have a bung welded in the downpipe but thats it. Other than that its just running the line to the engine compartment. It's very simple. As for the oil psi gauge its not that hard either. Depending on if you have an electric gauge or mechanical would be the case if your running nylon tubing/(or copper) or the wire for electric. Take your time and make it look nice and dont just throw the wires everywhere.
GL!
Old Apr 17, 2011 | 12:21 AM
RonPattonJr's Avatar
thanks for the info on this thread, I definitely was wondering the same thing.
ibarkovic
Evo X How Tos / Installations
48
Apr 15, 2009 09:07 PM
00cls1camaross
Driving Techniques
Aug 8, 2008 01:33 PM
warp9
May 8, 2008 07:10 PM
sekula
Sep 13, 2007 01:47 PM
03OZ_tuner
Oct 27, 2005 11:27 AM
