New tune, now it bogs bad off the 2 step?
Old May 6, 2008 | 03:34 PM
warp9's Avatar
I pretty much have an idea as to whats going on.
With my old tune (21 psi) with higher timing values I was getting strong launches off the 2 step set at just 5906 RPM. Now with my new tune (25psi) with much lower timing values I just bog horribly off the 2 step set even as high as 6100 RPM. What can I do to remedy the new tune to launch? Increase the timing at the 2 step load values? Any help is appreciated.
Old May 6, 2008 | 10:31 PM
warp9's Avatar
anyone?
Old May 7, 2008 | 06:33 AM
scheides's Avatar
EvoM Moderator
Log the car and see what is happening. I have seen knock go through the roof doing 2-step, and then the car is stuck in the low-octane maps until it can recover.
Old May 7, 2008 | 07:09 AM
bnice01's Avatar
boost would build more if the ignition was retarding and adding fuel from the ecu interpolating between the high & low octane map
Old May 7, 2008 | 08:26 AM
warp9's Avatar
I think that was the problem. I actually went down to 5800 and it fixed the problem. It kinda seems backwards but it worked.
Old May 7, 2008 | 08:38 AM
recompile's Avatar
It helps to slowly ramp to the 2 step, don't just mash the pedal. That usually prevents knock
Old May 7, 2008 | 09:30 AM
warp9's Avatar
Good advice...thanks.
Old May 7, 2008 | 09:38 AM
hellcat's Avatar
This is what I do. Mine is set at 5300 rpm and I don't bog and pull 1.7 consistantly.
Old May 7, 2008 | 04:10 PM
chmodlf's Avatar
My logs confirm the above.
Old May 7, 2008 | 09:20 PM
Jack_of_Trades's Avatar
What boost levels and loads are you seeing during the "stationary rev limit"? I don't see why any peak boost changes would ever effect this area of the tune? Especially in the higher rev ranges. I could see if you were in the "ramp-up" areas but thats wayyyy lower in RPM.
Old May 8, 2008 | 06:21 AM
bnice01's Avatar
probably there is less timing and more fuel were it engages now. usually the 2step load is between 120-160.
Old May 8, 2008 | 03:19 PM
Well, I certainly never alter my 5500-6500 rpm/120-160 load areas when tuning for different boost levels.
Old May 8, 2008 | 07:10 PM
bnice01's Avatar
You never know what the tuner did
Evo-IXse06
Aug 10, 2015 03:21 AM
kanyonkid
Jul 16, 2011 10:33 PM
Mellon Racing
38
Jul 18, 2008 05:55 PM
Xcited
May 1, 2008 11:52 AM
