Clock Fuse?
Old Sep 21, 2004 | 09:13 AM
scots04rally's Avatar
Clock Fuse?
Is there one? I was running a power wire to the power wire on the clock and it heard something, sounded like a fuse blown....cant seem to find a clock fuse in the manual....There was power to the clock and since i heard that sound...it dont have power no more...so im guessing there has to be a fuse....but where is it? Thanks in advance!
scot
Old Sep 21, 2004 | 09:27 AM
otter's Avatar
EvoM Administrator
Check the fusebox under the dash. Driver's side, down low, behind that little compartment that I can't find a use for.
Old Sep 21, 2004 | 09:28 AM
I see the fuse box but which fuse is it?
Old Sep 21, 2004 | 09:32 AM
Evios's Avatar
check owners manual
Old Sep 21, 2004 | 10:02 AM
Originally Posted by Evios
check owners manual
Im looking in the manual and see nothing about a clock fuse
Old Sep 21, 2004 | 10:09 AM
Kmfdm's Avatar
I cant find in the manual that one or the one that makes that damn "put on your seatbelt" beeping.Anyone know how to shut that thing off w/out using seatbelt?
Old Sep 21, 2004 | 10:12 AM
psy-q's Avatar
scots04rally: the fuse diagram is on the side of the box you pulled out to get to them.
Kmfdm: there is no fuse for that. Use your damn seatbelt.
Old Sep 21, 2004 | 10:14 AM
Kmfdm's Avatar
Old Sep 21, 2004 | 10:30 AM
Evios's Avatar
...Use your damn seatbelt.
LOL good call.
Old Sep 21, 2004 | 10:53 AM
I see that diagram....but nothing for a clock
We have check all the fuses and all have power.....think there is an inline fuse thats blown?
Old Sep 21, 2004 | 11:00 AM
psy-q's Avatar
Sounds more like you've blown up your clock. Pull it out and pull it apart. If you've hurt it the fact that it made a sound should make any damage apparent.
Post pictures of the destruction
Here is the delimma. I am hooking up a shift light.....I was gonna run the power and ground in with the clock. I ran the power wire from the shift light into the power for the clock. When i did that, the clock stopped working....no power from power wire going into clock....so then i noticed the memory wire was getting power.....so i ran the power wire from clock into memory wire....battabing! clock works again....from there i ran the power wire from shift light into the memory/power wire...and then ran the ground wire into the ground wire going into the clock......battabing! Clock and shift light work....i test this numerous times by cutting the car on and off several times....go to put the dash back on and hook up the clock and flashers.....and it stops working.....checked all connections and they are good.....WHAT IS THE PROBLEM??? this is so frustrating
Old Sep 21, 2004 | 11:04 AM
psy-q's Avatar
Sounds like the clock is designed to have power from the car when running, and a continuious flow while the car is off to keep time. You've shorted something somewhere, or putting too much/too little juice to the clock.
Put it all back together and tap your power off the lighter socket. That thing has 100x more power then it needs anyways. It also has it's own fuse.
Old Sep 21, 2004 | 11:11 AM
What about the clock? Are you talking about the lighter socket in the middle console?
Old Sep 21, 2004 | 11:13 AM
psy-q's Avatar
Yeah, forget about tapping the power off the clock. That lighter socket has MAD juice
