throw out bearing
Old Jan 18, 2015 | 12:50 AM
deathsythe99's Avatar
throw out bearing
Im looking for a diy gor this I have no idea where its located please help.
Old Jan 18, 2015 | 07:12 AM
CrAnSwIcK's Avatar
in the bell housing, on the clutch fork...pull the transmission off.
Old Jan 18, 2015 | 09:21 AM
Where is that? One thing I did notice is this thing moves ALOT I walked out of the car and I could smell clutch. When the car is off the gears go in fine
Old Jan 18, 2015 | 09:22 AM
Forgot to upload the picture lol.
Old Jan 18, 2015 | 01:47 PM
CrAnSwIcK's Avatar
that's your slave cylinder...what do you mean it moves a lot? also the metal thing that goes inside the bell housing, that's the clutch fork, the throwout bearing is on the other end of that.
the slave, you should be able to push the clutch fork towards it, and it should be fairly difficult and then it should return to center on it's own. you should not be able to move it the other way by hand, and it shouldn't have any free play (wiggle) if it does, your throwout bearing probably fell apart.
Old Jan 18, 2015 | 06:11 PM
Does that mean my clutch is soon to fail aswell?
Old Jan 18, 2015 | 09:27 PM
CrAnSwIcK's Avatar
if the bearing is destroyed, it could destroy the pressure plate springs, and you could end up punching holes through the transmission case...something like this:
Old Jan 18, 2015 | 09:33 PM
CrAnSwIcK's Avatar
normally, the face of the bearing that presses against the pressure plate springs to release the clutch, will spin with the flywheel (pressure plate is bolted to the flywheel), allowing the clutch disc to spin freely in between the flywheel and pressure plate, allowing transmission speed and engine speed to be independent. the squealing you hear is likely the broken bearing pressing against the springs, and being unable to spin, is just metal rubbing on metal...if it doesn't completely fall apart and explode, it will eventually rub through the springs, then get jammed and explode...
here's what the fork and release bearing look like inside the bell housing:
Old Jan 19, 2015 | 06:32 PM
Ok so i need a new clutch we just looked at it more closely. Question now is what clutch should I go with? Im not going for big power im doing 168/169 here at 5280' high. Yes I have mods done so maybe act?
Old Jan 19, 2015 | 08:13 PM
CrAnSwIcK's Avatar
you could honestly go OEM, but if you don't drive in stop and go traffic very often, a stage 1 is really nice, and still forgiving like OEM, just stiffer on the pedal...anything above stage 1 engages harshly, is not very forgiving, chatters, and is noisy.
Old Mar 17, 2015 | 09:17 AM
rzrxn's Avatar
i haven't been on EvoM for quite some time now as i've been so damn busy with work and school. i decided to open up 20 tabs of EvoM material and i came across this. i always just shake my head at myself when i hear 'throwout bearing' bc mine has been rattling for so long.
@garrett:
i still need to schedule a date and time with you. it's been a while brother. work just consumes my time and energy. i will definitely call you up when it gets warmer though!
@deathsythe99:
go OEM or look around locally for a parts store that sells it. you should check out RTM Racing! see links below:
1) https://www.rtmracing.com/xcart/prod...at=1843&page=1
2) https://www.rtmracing.com/xcart/prod...at=1843&page=1
cheers!
Old Mar 17, 2015 | 10:08 AM
CrAnSwIcK's Avatar
Originally Posted by rzrxn
@garrett:
I no longer have a spare shaft for you...I mean I do, but it was suscepted to a high volume of metal shavings...so I mean, I could rebuild your shaft, but it will increase down time...
Old Mar 17, 2015 | 10:45 AM
rzrxn's Avatar
oh that's a bummer! well at least i get to learn how to rebuild the shaft plus i know i'll learn a lot more from just cracking the trans open.
this summer i'm dead set on getting my RA in tip-top shape. i already started taking care of a bunch of things that i can do myself. it's just so hard to get anything done since my 93 Jeep Cherokee is stuck in the garage right now. i have no space to work with.
TRAMP will be revived this Summer 2015. that's for sure!
thanks again man! you're always a great encouragement!
#RalliartLife
Old Mar 17, 2015 | 10:49 AM
rzrxn's Avatar
@deathsythe99:
sorry for hijacking your thread bro! let us know if you need any help on your clutch/bearing issue. this forum is an amazing resource. trust me. i learned TONS of stuff just by reading/searching around. cheers my friend!
Cj98
Jun 28, 2013 12:00 AM
Cloudx71
Sep 10, 2011 01:14 PM
VegasEvoOwner
71
Mar 7, 2005 07:32 PM
spyderturbo
Jul 25, 2003 11:41 AM
