problem with tein basic coilover
Old Jul 29, 2006 | 07:19 PM
ralliart67's Avatar
i have a problem, i purchased a set of tein basic coilovers for my 06 ralliart, have them installed and set up as to the intstructions, the problem is when the car is stoped and i turn lock to lock i hear a creeking sound from the left front, i have narrowed it down to either the strut bearing or mount, i replaced the upper bearing and i still hear the creeking sound, i would like to know, has anyone had this problem, and if so what was the fix,, Wondering if you guys that have the tein basic coilovers could take the time and see if your car does the same,, maybe its the charateristic of the car,,, i'm losing my shirt tring to figure this out,,,, much appreciated,,,,,,,,,,,,,,,,,,
Old Aug 1, 2006 | 11:36 AM
Wallesasuaz's Avatar
OKAY... Did you drop your car when had them installed? how low is your car? If it's dropped considerably it's just your wheel hitting against the wheel well.
Old Aug 1, 2006 | 02:43 PM
ralliart67's Avatar
thanks for the reply,,, i droped my about 1.2 or 1.5 inches... i ajusted it 3mm or 1.2 inches from the bottom of shaft as the instructions said then installed them on the car, i know the wheels not rubbing, my s-techs would rub,,,,not as low as s-techs, i can put the front end of the car up and turn the wheel lock to lock with the wheels off and can hear it, its like a creeking - tinking noise,,,
Old Aug 1, 2006 | 02:57 PM
RallliartEVO6's Avatar
I think I know whats wrong with it. It is the little rubber thing the spring sits on, the creeking noise if from the spring hitting the metal(makes the noise when u hit bumps). just get the rubber thing put back under the spring, and that should do it.
Old Aug 1, 2006 | 03:08 PM
ralliart67's Avatar
their no noise when i hit bumps, just turning, can be at a stop and turn my wheel lock to lock is the only time i hear it,,, but you could have something, maybe if i put a piece of rubber on the top cap that fits on the top spring, maybe the spring is rubbing on the brass cap when turning,,, or i can spray some lube up their and see if noisr goes away,,,
Old Aug 1, 2006 | 03:10 PM
ralliart67's Avatar
their's no noise when i hit bumps, just turning, can be at a stop and turn my wheels lock to lock is the only time i hear it,,, but you could have something, maybe if i put a piece of rubber on the cap that fits over the top of the springs, maybe the spring is rubbing on the brass cap when turning,,, or i can spray some lube up their and see if the noise goes away,,,
Old Aug 1, 2006 | 03:16 PM
also check the bottom one to
Old Aug 2, 2006 | 12:59 AM
PANGES's Avatar
I used to have Tein SS's... I think I know what's wrong. Figure out which wheel it's coming from and remove the coilover. Then check on the upper end of the strut, there's this silver metal perch. You might've put it upside down. I did that when I installed them on my 240sx and they did the exact same thing.
note: you're going to have to remove the stock strut/mount thing you re-used.
Old Aug 2, 2006 | 09:33 AM
ralliart67's Avatar
i know the perch is not upside down, cause the strut bearing goes on top of it, bearing only goes in one way, starting to think maybe its the springs creeking, different load on the spring at different angles when turning lock to lock,,, i sprayed the whole strut and spring last night, thismorning the noise quieted down abit, but you can still hear it , not as loud, i put them in on friday, maybe the spring needs to break in and loosen up, i'll wait a week and see if theirs a difference,
Old Aug 2, 2006 | 03:37 PM
ralliart67's Avatar
okay... so after work i stoped in at mitsubishi .got a tech to look at my car, he heard the noise thats drivimg me crazy, took my car in the shop,, a half hour later my car was ready, i said what was the problem,, he replyed, no fault found, i said what...... he said everything seems o.k, install was good,, said its comming from upper left strut, the bearing and mount are good,,, now i'm confused,,, all well, turn up the radio and drive her till she breaks,,,,,,,,
Old Aug 2, 2006 | 03:47 PM
PANGES's Avatar
wtf... email whoever you got the coilovers from and ask them to give you a new one... they should'nt be making that kinda noise if everything's installed right.
Old Aug 2, 2006 | 04:09 PM
ralliart67's Avatar
already did, called jrp, they said they don't take back tein products, that they have to contact tein u.s.a, and would call me tomorrow,,, i know what a bunch of crock, before i raise sh** , which i'm pretty good at, give them till tomorrow to get back to me,,,, don't take back tein products,,, yeah right, they said they never had one set come back, including their normal lowring springs,,,,
MitsuJDM
15
Aug 28, 2019 07:43 PM
SmoothRA04
Mar 3, 2007 03:32 PM
ralliart67
12
Aug 26, 2006 12:01 PM
Lightsped
Feb 24, 2004 10:08 PM
Bitnode
14
Oct 3, 2002 12:29 AM
