Broken lug stud, when to replace?
Old Dec 5, 2012 | 09:08 AM
johnnycage's Avatar
I discovered the other day when inspecting my car after I got my winter tires put on that one of the lug studs is broken. Obviously theres enough there otherwise the wheel wouldn't be staying on but I am concerned about its strength. Now as you can see in the photos that the broken lug has rust, I imagine it was like this for quite some time before I purchased the car back in March so it may be fine indefinitely, however I thought I would see what you guys think. From what I can tell, about 7mm of the stud is gone. Think I should be concerned with fixing this soon?
Old Dec 5, 2012 | 09:51 AM
Thomar's Avatar
three quarters of a centimeter? lol...
I would probably fix it within the week. Maybe a weekend job.
Old Dec 5, 2012 | 10:29 AM
2006_RA's Avatar
It's not a big deal, change it at your convenience if at all.
If we ever meet before you get to it, remind me to bring you a stud.
I have a spare.
Old Dec 5, 2012 | 10:34 AM
manthny18's Avatar
not a really big deal i drove a whole winter with a broken stud. but fixed when it got warmer.
johnnycage's Avatar
err about 7mm hah.
Old Dec 5, 2012 | 06:08 PM
CrAnSwIcK's Avatar
i run 8mm spacers on stock studs, i think you're ok if you're only missing 7mm off one stud...
Old Dec 6, 2012 | 06:17 AM
RalliartN's Avatar
Go on kijiji and locally get a full set of proper Mitsubishi stock lug nuts for about $20.
Buy a new stud at the local parts store, press out the old and press in the new, a C-clamp will probably do it, although I haven't looked to see if there is clearance around the hub to do that.
Old Dec 12, 2012 | 01:31 PM
nekkidlad's Avatar
ull be fine if only one lug is missing...i wouldn't go racing but ull be fine...
..not a big issue...just do it whenever u get a chance...
not hard to do at all...
Old Dec 15, 2012 | 05:41 AM
Jrose42488's Avatar
Time to upgrade to ARP Hardware? :-)
Old Dec 17, 2012 | 09:43 AM
nekkidlad's Avatar
doesn't need to be...unless you're constantly auto-x-ing...
and even then it should be fine either way...just a safety measure...
Old Dec 17, 2012 | 04:39 PM
Smike's Avatar
You have uneven torquing of the wheel to hub without all 4. Replace.
Its super easy and under $10.
EvoooB
Mar 30, 2015 09:16 AM
SmoothdrJay
Mar 14, 2009 08:36 PM
antilag_200
Feb 25, 2008 09:26 AM
crazy4ozs
Aug 12, 2007 03:43 PM
modelchris
Dec 18, 2005 05:06 PM
