Ok, so has anyone actually bought one of these yet?
Old Oct 4, 2008 | 05:23 AM
  #46
chino ali's Avatar
If you look under the number 17 on the MPG right on the sticker, there is small print, stating that normal drivers are averaging 14-20mpg in the city.
And if you look under the 25mpg for hwy, it states an normal average 20 - 30 mpg..
So you can more MPG out of it, conservatively.
A reflash can help and probably an ECU tune.
Old Oct 5, 2008 | 11:17 AM
  #47
BlueVette's Avatar
If that doesn't void your warranty
Old Oct 9, 2008 | 06:13 PM
  #48
Nik128's Avatar
As far as MPG goes, the government recently changed the terms for estimating the MPG, so pretty much all 2009 models are now showing up to 5 MPG less than previous models, even for some identical cars. So keep that in mind. I think the new RA suffers in MPG largely because of its weight, but on the highway it can probably easily achieve 28 @ 65-70 mph.
Old Oct 11, 2008 | 08:20 PM
  #49
Nik128's Avatar
I found the article that explains how 2008 and later car models are tested. The changes are quite significant, probably resulting in 10-20% difference ! Things like AC are now used, while in the past they were not
* Higher speeds - up to 80 MPH on the highway cycle
* Colder temperatures - tests will now start at 20 degrees Fahrenheit rather than 75
* More rapid acceleration
* Use of accessories - the air conditioner will be operated 13% of the time
source:
http://cars.about.com/od/fueleconomy...pg_testing.htm
Old Oct 11, 2008 | 08:28 PM
  #50
lookslikeanevo's Avatar
Who the hell buys a performance car..or a cross performance car and worry about gad mileage!>? i dont get it...
Old Oct 11, 2008 | 08:42 PM
  #51
hibby's Avatar
Somebody in touch with reality?
Old Oct 12, 2008 | 05:51 AM
  #52
dboz's Avatar
Keep in mind that these are economy cars. Not Porsche and Lambo. They are daily drivers. No one wants a car that is getting 15 MPG as a daily driver unless you have no other obligations in life and you live at home with mom. It is just a waste of money.
Old Oct 12, 2008 | 08:23 AM
  #53
otter's Avatar
EvoM Administrator
You can't seriously expect to buy a quick turbo AWD sedan and get decent MPG. Just look at Subaru's lineup. Even their NA cars only get 20/26. At this point in time, you're not going to find a fast yet economical car. At least not until the more lightweight cars start rolling out with better engine designs.
Old Oct 12, 2008 | 08:24 AM
  #54
chino ali's Avatar
Yeah, Hibby
I agree.
When i bought the CSRT4 i was thinking still the MPG on the car.
The CSRT4 gets 22/29 city/highway and it's a turbo@285hp. I drive it hard and still get at least 19-20 in the city.
R/A should be getting at least 19.
The Lancer gets 25/34 city/highway and my supercharged Scion get the same as the R/A with a small difference.
The R/A,GSR and MR gets 17-19/24-27 city/highway. Why buy a R/A if your gas consciouss and can get a GSR or MR that does the same?
Old Oct 12, 2008 | 01:31 PM
  #55
dboz's Avatar
Ever heard of the Cobalt SS?
Old Oct 12, 2008 | 02:24 PM
  #56
hibby's Avatar
Not that I especially like the Ralliart's fuel economy numbers, but...
FWD
FWD, FWD
FWD
Old Oct 12, 2008 | 02:33 PM
  #57
heavyD's Avatar
If MPG is high on your list of priorities you should stick with N/A engines only as I've never owned a turbocharged car that got decent gas mileage.
Old Oct 12, 2008 | 02:39 PM
  #58
dboz's Avatar
WRX gets low 20's city and up to 30 hwy.
My priorities are for a fun car that is still economical. If MPG is no issue, I may as well get some real power and get a G8, Camaro, Challenger. Not on a 4 cyl turbo econo car.
Old Oct 12, 2008 | 02:44 PM
  #59
heavyD's Avatar
WRX won't get those numbers unless you drive it like a Civic. So why not just get a Civic? Go to NASIOC and you won't see anyone there claiming decent gas mileage.
Old Oct 12, 2008 | 03:07 PM
  #60
ambystom01's Avatar
I average between 24 MPG and 30 MPG and I don't drive like a grandma, I just drive smart. At the track this plummets to 7 MPG.
