HID headlights
Old Jan 4, 2009 | 10:16 PM
Darkburner's Avatar
HID headlights
anyone know were i can get a set of hid headlights, and i dont mean the xenon converstion set, i mean like the ones that come with the recaro package. (dont like the stock ones...)
edit: i wont mind some hid fog lights too
Old Jan 4, 2009 | 10:27 PM
ambystom01's Avatar
If your car didn't come with HIDs, you need a conversion kit.
Old Jan 4, 2009 | 10:45 PM
captg's Avatar
I think they want to swap out their headlights for OEM HID's?
Old Jan 4, 2009 | 11:06 PM
ambystom01's Avatar
I figured that but it's not a simple swap. To use all OEM equipment would cost 2 to 4 times what it would to go aftermarket. You'd need the HID equipped headlight housing, you'd need the bulbs, you'd need all the wiring and all the switches. I wouldn't be surprised if that cost over a thousand dollars right now. By comparison you can buy a conversion kit for 150$-400$ depending on what you want.
Old Jan 5, 2009 | 12:36 AM
captg's Avatar
See if Lightwerkz is willing to work with you and see if they could do a retrofit for a Ralliart! That would be the one of the best solutions and cleanest. They would be S2000 or TSX projectors. http://www.lightwerkz.net/
Old Jan 5, 2009 | 04:25 AM
angryGTS's Avatar
I dont care much for the HIDs I just want some projectors hopefully someone will release a set
Old Jan 5, 2009 | 04:46 AM
mmartahus's Avatar
^ +1
Old Jan 5, 2009 | 10:22 AM
captg's Avatar
That's what lightwerkz.net does. You could opt for no HID probably.
Old Jan 5, 2009 | 01:36 PM
HEXTALL27's Avatar
Why didn't you just get the Recaro package with the HIDs?? Everything would be factory...the cost would be rolled into the loan and there is a lot less hassle.
Old Jan 5, 2009 | 01:42 PM
tvbf1's Avatar
He probably got a really good deal on his car, and probably thought that he could upgrade to HID/projector headlights later or something.
Old Jan 5, 2009 | 07:44 PM
Darkburner's Avatar
^^^^ +1 also they didnt have any fulliloaded ralliart or recaro package, only 2 base models and one with navi so... took the the navi (29k otd not too bad)
-Quote-
See if Lightwerkz is willing to work with you and see if they could do a retrofit for a Ralliart! That would be the one of the best solutions and cleanest. They would be S2000 or TSX projectors. http://www.lightwerkz.net/ -Quote-
thanks ill check it out
PS:my last resort is the dealership
Old Jan 5, 2009 | 08:10 PM
HEXTALL27's Avatar
Maybe you can find lights from a wrecked Evo that had the projectors and HIDs. I gotta admit.. I HATE the lights in my WRX. They are total garbage compared to my wifes Scion TC with projectors so I can understand why you wanna upgrade.
Old Jan 6, 2009 | 03:02 PM
angryGTS's Avatar
Because none of the dealers around here bothered to order any with that package, they didnt think the cost of the package was worth what you got, Recaros, headlights, and a sound system.
Old Jan 6, 2009 | 05:10 PM
EricJ@AMS's Avatar
We tried swapping HID lights into a non-hid evo X. The factory wiring is different and it will not work. Same would go for the Ralliart.
You will have problems with an HID kit in a standard Evo/Ralliart too. The car uses the lowbeam light at reduced voltage as the daytime running light. This will throw the ballast of an HID kit into a frenzy and you would have to make sure you turn the headlights on before the daytime running lights activated.
Old Jan 6, 2009 | 05:14 PM
GiLizILL's Avatar
just upgrade the bulbs
