From the EvoX engine mgmt/tuning forum..
Old Jan 14, 2009 | 09:25 AM
madcows's Avatar
https://www.evolutionm.net/forums/ev...advantage.html
Very similar, if not the same results (scaled down, though) could be had for your R/As
Old Jan 14, 2009 | 10:57 AM
GiLizILL's Avatar
what does this mean? lol, im a little lost
Old Jan 14, 2009 | 12:46 PM
captg's Avatar
I think, madcows is just pointing out how tunable our engines are.
Old Jan 14, 2009 | 03:21 PM
madcows's Avatar
The camshaft timing on the 4b11t (evoX, R/A engine) is dynamically adjustable (in the sense that the ECU can control it). The current map (basically the instructions on when/how much the ecu will adjust them) that is loaded into the ecu is not so great. With a better tuned map (like the one GST has made), it's possible to squeeze out a nice chunk of additional power throughout the rev range. This is on top of all the rest of the power you can gain from a tune.
Old Jan 16, 2009 | 11:17 AM
Chris@AMS's Avatar
Its true! Intake and exhaust cam timing are completely configurable in our flashes. They are optimized for the best spool up and power on the Ralliart. While the gains are noticeable for sure, they are not as dramatic because of how quickly the Ralliart enters boost.
Old Jan 16, 2009 | 11:50 AM
captg's Avatar
So your tunes are utilizing this?
Old Jan 16, 2009 | 12:22 PM
Chris@AMS's Avatar
yes!
