Zchip vs ecu flash
Old Jan 27, 2009 | 05:02 PM
  #46
ambystom01's Avatar
Originally Posted by madcows
It's not just SST program. With the X, changing the load values in some way affected what the SST was doing. It's not fully understood just yet, but you can get more power while avoiding "torque protection" with a full reflash. Like I said in an earlier post, if someone wants a tune, it should just be a mild one for now, anyways.
That doesn't make any sense to me though. That's like saying that lifting 1000 lbs with a machine is better for your muscles than lifting 1000 lbs with free weights, it doesn't how you do it, if you exceed the muscle's ability, you're going to damage it.
Old Jan 27, 2009 | 05:09 PM
  #47
madcows's Avatar
You're right, but only if there was a physical mechanical problem... But there is nothing that indicated that "torque protection" was due to failure or slipping on any mechanical part, but rather activated via software.
Old Jan 27, 2009 | 07:19 PM
  #48
desperado-c's Avatar
Originally Posted by JONralli09
thats true, weather and altitude makes a big difference. ....
You can use SAE correction for different weather conditions and altitude is not very significant in turbo applications. But different types of dynos, yeah, that matters alot. In any case, 265-275 ft-lbs at the wheels is pretty good for a car that comes stock with 254 ft-lbs at the crank. I could definitely live with that. Especially, if it can be held long enough to get some good increases in hp for hauling that fat boy around.
Old Jan 30, 2009 | 11:36 AM
  #49
Euripides's Avatar
Wonder what would happen , if you flash the ECU with ECUtek, and install the Z-chip....
hmmmm
Old Jan 30, 2009 | 03:08 PM
  #50
madcows's Avatar
hmmmm
You don't want to do that... If you're going to flash your ECU, the zchip would be unnecessary, if not dangerous.
Old Jan 30, 2009 | 05:20 PM
  #51
Robevo RS's Avatar
hmmmm
probably something costly
