Carbon on exhaust tips
Old Feb 5, 2009 | 08:04 AM
GiLizILL's Avatar
I noticed that there is a decent amountof carbon that gets accumulated on the exhaust tips from my 09RA. Anyone else having this little issue? What can be done to prevent that. Is that good or bad? Im a little unfamiliar with this.
Maybe a KN drop in can help?
Old Feb 5, 2009 | 08:45 AM
DatRAzn's Avatar
I've noticed the same thing on my car. Usually a damp terry cloth gets it off the tips pretty easy. Had the same issue in my old 05 Tibby.
If its good or bad...I'm in the same boat.
Old Feb 5, 2009 | 09:00 AM
Euripides's Avatar
I have it, had it on my GTI with stock, and aftermarket exhaust..doesn't concern me anymore haha
Old Feb 5, 2009 | 09:07 AM
elpoole's Avatar
Even with my full aftermarket exhaust i get carbon build up. Its due to the car running rich which is better than it running lean. Running lean increases temp. Ive heard that it doesnt run as rich as the evo though. I wont have any real data for another week or so.
Heliart's Avatar
Yeah the carbon does accumulate on the exhaust tips fast.....there's already more carbon on my Ralliart's exhaust tips with only 5000 miles than my 7 yr old 2003 Tiburon with 160K miles.....
Old Feb 5, 2009 | 09:40 AM
Kurt's Avatar
Your car is just running rich. Most manufacturers tune turbo cars rich to keep them from going boom. Case in point. I can clean the exhaust tip on my MS3, drive to work(40 miles), and the tip will black again. I thought it was odd at first too, but I really don't worry about it. A tune should fix your problem and my problem. I could be wrong.
Old Feb 5, 2009 | 09:47 AM
GiLizILL's Avatar
^well i have the z-chip. wouldnt a tune not go well ontop of that?
Old Feb 5, 2009 | 10:11 AM
CaSilvia's Avatar
Turbo cars run rich, richness=excess carbon, deal with it. Heaven forbid any of you guys get a test pipe...
Old Feb 5, 2009 | 08:33 PM
JONralli09's Avatar
yep noticed carbon on my tips too..kinda expect it from the turbo..IdriveRA have you logged your data from zchip? is your dyno map the exact one they have posted at the thread?
Old Feb 5, 2009 | 08:37 PM
rocknsnoboarder's Avatar
+1
Doesn't hurt anything and wipes right off so your exhaust can be shiny again if you park it where people will be seeing it.
Old Feb 6, 2009 | 08:14 AM
elpoole's Avatar
I would think a tune would lean you out a bit and reduce the carbon buildup plus add a ton of HP.
The Zchip is the way your car it tuned and I bet it could be tuned further to get you more HP and lean it out a bit, but you better talk to TTP about it to make sure your tuning safely.
Old Feb 6, 2009 | 08:38 AM
otter's Avatar
EvoM Administrator
The only way to prevent it is to not drive the car.
If you want to clean it up, use some 0000 steel wool to remove it and polish the tip, but I'm sure you'll get sick of doing that once per week.
Old Feb 6, 2009 | 01:06 PM
elpoole's Avatar
But isnt having excess carbon a sign that a tune could help you out?
Old Feb 7, 2009 | 03:21 AM
Having a LOT of black carbon on the tip would be a bad thing, but unless you are at 100% combustion of all the fuel and have zero exhaust emissions then you're going to get some build up on your exhaust. Like it was posted earlier, our cars are typically tuned to run rich rather than lean because it's a safer condition.
Old Feb 7, 2009 | 04:08 AM
desperado-c's Avatar
n/m, DI is sootier than port injection so probably not relevant.
