My ttp tune and dyno
Old Apr 22, 2009 | 03:26 PM
  #31
JONralli09's Avatar
um i did not in any way bash them. I voiced a concern i had with the tune. This is what a forum is for, to get information about issues with the car and see if anyone else had the same issue. If i didnt get a response like i said above about them letting me know that there is some progress going on with my tune, isnt that like leaving me in the air??And no it hasnt happened YET.
Old Apr 22, 2009 | 05:20 PM
  #32
Jeremycafe's Avatar
This was the only reason I really came to post after my tune up as well. I simply wanted to know if the problem i appeared to have was something users on here would know of.
Old Apr 22, 2009 | 06:54 PM
  #33
GiLizILL's Avatar
^ exactly, we are consumers. We can voice our opinion/problems if anything is wrong. It was our hard earned money.
Companies shouldn't get defensive, instead they should deal with the problem promptly and answer any questions in a timely manner, to secure future business.
Old Apr 23, 2009 | 12:40 AM
  #34
Bom's Evo's Avatar
Have you tried the boost pill with the chip?
Old Apr 23, 2009 | 04:49 AM
  #35
JONralli09's Avatar
thats what im using, the boost pill.
Old Apr 23, 2009 | 05:09 AM
  #36
GiLizILL's Avatar
I'm just surprised TTP, let you walk out with a ECU code/limp mode. Knowing that the previous RA's they tuned had the same problem. I would have thought they fixed it by now.
Old Apr 23, 2009 | 06:14 AM
  #37
Jeremycafe's Avatar
I kind of wish I went with with the zchip even if it may be having problems. Not sure if losing the warranty was worth the tuning with no mods in the car :\ my fault for not doing research. damn.
Old Apr 23, 2009 | 07:33 AM
  #38
TTP Engineering's Avatar
Reflashing your ECU does not void your warranty.
Old Apr 23, 2009 | 07:46 AM
  #39
Jeremycafe's Avatar
Really? Glad to hear that. Was debated here at the office and one person claimed he was certain it does.
Google and dealers seem to say it does (depending on how lenient the dealer is)
Old Apr 23, 2009 | 09:47 AM
  #40
nj1266's Avatar
Yes it does void the warranty. You are tampering with the ECU. If your engine is damaged and the dealer finds out that you have altered the ECU, then he will void the engine warranty on the damaged parts of the engine. Since the ECU controls the behavior of the engine, then it is very easy for the dealer to claim that changing the ECU data damaged X part in the engine.
Old Apr 23, 2009 | 09:56 AM
  #41
Prove any case whatsoever where a 4b11t warranty was voided over an ECU reflash.
If you cannot, then you are not adding any accurate information to this thread.
Old Apr 23, 2009 | 10:07 AM
  #42
Jeremycafe's Avatar
What I found online is claims that some dealers with check if the ECU was touched before doing any work on it and if it was they wont touch it at all regardless of the problem. But that is just word, and I dont expect to have problems. Just wondering.
On a side note, are there any intakes that are blessed by mitsu?
Old Apr 23, 2009 | 10:16 AM
  #43
Drows's Avatar
Are you guarantying this then? That if someones car you flashed gets voided because of flash you'll cover costs? I'm not saying you're wrong, I just find it hard to believe that a car manufacturer wouldn't be smart enough to cover their asses for someone changing something so critical as a ECU. Can you post your source please. Thanks (You will make alot of Ralliart people VERY happy if this is true)
Old Apr 23, 2009 | 10:32 AM
  #44
Jeremycafe's Avatar
When i was trying to find the answer online all I was able to find were people talking about how the newer cars (specifically the evo X) have a 'fail safe' that detects if the ecu has been re flashed to stock settings. If this is true I don't understand why they would go through the trouble of determining if the ECU has been played with if they dont care. I dont know if the ralliart supposedly has this in it though.
But in general is seems people's response from dealers were either they wont touch the car or they will turn a blind eye to it.
Old Apr 23, 2009 | 10:33 AM
  #45
Jeremycafe's Avatar
I am going to fire off some emails to the mitsu dealers around here and ask them about flashed ECUs and how they deal with them and how warranties are effects. Problem is I will probably get answers from people who have no idea and just assume it voids them.
