Oil filter database for Lancer Ralliart
I could not get the Stock OEM filter off for the life of me!
I broke a new filter socket (crap blk plastic ones) and could not get the wrench type to fit in the tiny area around the oil filer to get it off. I just changed the oil and will leave it on till my actual 5k oil change where i may bring it in to get that sucker removed or find a better solution.
Anyone else have issues getting their first filter off, I swear
over torqued this thing so I would have to bring it in!?
I broke a new filter socket (crap blk plastic ones) and could not get the wrench type to fit in the tiny area around the oil filer to get it off. I just changed the oil and will leave it on till my actual 5k oil change where i may bring it in to get that sucker removed or find a better solution.Anyone else have issues getting their first filter off, I swear
I got a metal oil filter socket from pepboys and I got mine off last time with no issue...can't remember the size tho I guess i can look that up later.
and btw I used K&N filters for the past 2 years and recently switched to OEM because it's half the price of K&N. I have not noticed any differences (probably never will).
I've been a fan of AMSOIL for a while so for the RA I use:
Ea15k13
http://www.amsoil.com/catalog.aspx?code=Ea15k13-EA
Ea15k13
I got a 80mm x 15 flutes oil filter metal socket from Pepboys ($6). I originally bought it for my Genesis Coupe and later found out that the Mitsubishi OEM is the same size.
Has anyone conformed that the Honda filters are the same? Oem Honda filters are very well made pieces would not mind using those at all. Honda uses the same thread and seal area on all there 89+ cars so if it fits you can get the bigger s2000 filters.
On amsoil site, the search return this wis filter, 51356
http://www.amsoil.com/mygarage/Produ...BISHI+LANCER+V
It is ok to use this one with a lancer ralliart 2009??
I already order before i saw this thread and im a little confuse
Thx
Thx
MR. EVO MR
679
Dec 1, 2016 05:14 PM
nybluelancer
Lancer Aftermarket Forced Induction Tech
Jan 30, 2016 09:14 PM
spartan117
15
Aug 2, 2010 09:50 AM
