Acceleration Sucks!
Old May 22, 2010 | 03:48 PM
Skym's Avatar
There is a difference in normal and sport in manual mode. Sport mode shifts faster
Old May 22, 2010 | 04:59 PM
Cosis's Avatar
isnt this a commonly known fact? Like i dont get the purpose here myself. Accelleration sucks.. hmm, you know, i dont think anyone else had noticed.
I think a better way of going about this would be, how do i get rid of some of the lag off the line. Tune or just an exhaust/filter or x turbo, or sprint booster.
Lots of ways to limit the amount my friend.
Old May 22, 2010 | 05:58 PM
Skym's Avatar
Well... so what is the best way to get rid of it besides getting a new ride lol
Old May 22, 2010 | 06:11 PM
RotorGlow's Avatar
You can limit it, but not eliminate it.
Although I believe secondchase installed some sort of throttle device that got rid of the lag. He would have to confirm it though.
Old May 22, 2010 | 06:16 PM
Skym's Avatar
Yeah there was a long discussion about that and it was just a throttle input amplifier. So that would be the only solution to limit it??
Old May 22, 2010 | 09:55 PM
Cosis's Avatar
It would help for sure. I think they are adjustable now too.
Old May 22, 2010 | 10:14 PM
ambystom01's Avatar
No it won't help, there is a difference between acceleration, throttle response, time to WOT and pedal sensitivity. The products in question act on the latter two and in some cases, only in a minor way (ie. time to WOT is reduced by fractions of a second). If you can push your foot down further, you can replicate what the products do for free.
Old May 22, 2010 | 10:55 PM
GST Motorsports's Avatar
I've been doing some testing on my personal Sportback and I no longer have his delay and throttle drop from WOT from a stop. It is completely gone.
However, this is a safe-guard for the trans. At stock or slightly higher then stock power I don't see an issue but after adding a good amount of additional power it might be a risk.
Next I will be dialing it back in, in small steps to see if I can good a good compromise between safe guard and response...
- Bryan
Old May 23, 2010 | 10:28 AM
PCToolsWiki's Avatar
Well besides the acceleration that sucks, the top end blows as well, but I know a tune can fix that.
Old May 23, 2010 | 10:48 AM
Psycho09RA's Avatar
So what did you do to get rid of the delay?
Old May 23, 2010 | 12:22 PM
ambystom01's Avatar
I'm guessing he retuned the throttle map.
Old May 23, 2010 | 02:14 PM
There are some tables that control throttle pull, meaning the ECU will pull down the throttle if it sees things over a certain limit.
Here is a logged occurance of what you guys are feeling:
- Bryan
Old May 23, 2010 | 03:25 PM
sith_killer_99's Avatar
Tiny turbo falls flat on it's face at higher speeds.
I have felt this too often. Guess I should just keep it under 120. lol
Old May 23, 2010 | 04:29 PM
vincentchua's Avatar
- Bryan
So do tuners normally address this issue while tuning AFR/Boost/Mivec timing etc? Or is this something that you're currently researching?
How do you access and tune this - do you have to use any specific software e.g. Ecutek etc?
Cheers...
Old May 25, 2010 | 10:56 AM
Ladogaboy's Avatar
This might not be what you want to hear, but if you wanted a car designed for the drag strip and top end, the RA was probably not the right choice for you. I seem to remember that, when you were initially deciding on the car, you wanted something that would be a reliable, sporty daily driver. The RA is all of those things. It is not, however, a dragstrip queen or something you would take to Bonneville.
