Acceleration Sucks!
The throttle position sensor (TPS) is reducing the signal (versus input)? I would 'expect' the TPS to be flat line at WOT.
Why doesn't timing advance more? A function of the turbo/compression and
need to pull timing to reduce knocking?
And what is the 'orange line'?
Thanks for all the newB questions and your patience.
So help me understand what i see here...
So you can see that 100% throttle is being requested (foot to the floor) but the ECU is pulling it down from requested.
Orange line is turbo solenoid duty cycle
- Bryan
How do you think this will strain the SST? Since I thought the purpose of that delay is so you aren't putting too much on the SST at launch.
