Wideband and Data Logging
Old Sep 11, 2010 | 10:56 PM
DaJackson's Avatar
I'm trying to decide on which Wideband I want to go with and have a few questions. I dont like the flashing colored lights of most digital gauges (UEGO) so I was planning on going with an analog gauge.
This is the one I think I'm going to go with.
http://www.aemelectronics.com/wideba...fuel-gauge-31/
I need the 8.5 to 18:1 gauge correct?
It has the 5v output, can I use these two connectors to hook up to my laptop for data logging?
http://www.mellontuning.com/index.ph...roducts_id=467
http://www.mellontuning.com/index.ph...roducts_id=295
Is there any major issue with running an analog gauge vs a digital one? Like I said I dont like the multicolor sweeping lights like on the UEGO and trying to read a constantly changing 3 digit number like a prosport is difficult. With the analog gauge I can just glance in the direction of the gauge and be able to see where the needle is.
Old Sep 12, 2010 | 05:52 PM
japan101's Avatar
Well AMS has also added some new electronics and stuff to their page as well. Could be worth a check just to see your options all around.
Old Sep 12, 2010 | 08:39 PM
>Cataclysm<'s Avatar
Topspeed is a vendor on here that offers Gauges for great prices and I think is also worth checking out or contacting them.
Yep, you need a usb to serial port and the wires need to be soldered to it. There is a How To on here for that. The ones from mellon are what you need but I think there is more and maybe cheaper options?
Old Sep 13, 2010 | 05:49 PM
DaJackson's Avatar
I have a local shop who I will be buying the gauges from.
As for the wires to data log, why do I need to solder? or do you mean from the other end of the serial cable to the gauge itself?
Those are the only cable Ive found that come pre-made.
Old Sep 13, 2010 | 06:00 PM
>Cataclysm<'s Avatar
yes, i believe so, if you want to log afr using a program like evoscan or something like it. I think its 2 but some wires from the gauge have to be soldered to the serial port on the cable so you can log it. I still can't find the thread but its on here somewhere. I could be wrong...
Old Sep 14, 2010 | 10:07 AM
EvoOtto's Avatar
https://www.evolutionm.net/forums/ev...ut-serial.html
I'm still not sure of how to setup ecuflash to read the WB. I have a Zeitronix ZT-2 and never installed it because I'm not sure of how to reprogram ecuflash to understand it. If anyone has a step by step for this I would really appreciate the help.
Old Sep 14, 2010 | 01:33 PM
DaJackson's Avatar
That walk through it to use the wideband to report info directly to the ECU then log that. I don't want to disable my rear O2 sensor etc, I want to use the serial cable and log from the gauge.
Mellon Racing
Evo 'For Sale' Electronics / Lighting / Audio
381
May 24, 2013 05:54 PM
Mellon Racing
Evo 'For Sale' Exterior Styling
Jun 27, 2011 07:03 AM
Mellon Racing
26
Jun 16, 2011 11:10 AM
Gary@MellonRacing
Sep 25, 2010 04:07 PM
Gary@MellonRacing
Evo 'For Sale' Engine Internals and Drivetrain
Sep 25, 2010 04:01 PM
