Parking Corner Light
Old Oct 8, 2010 | 05:40 AM
komilp13's Avatar
Originally Posted by 08Lancer89
I use. Vleds.com
Two questions: What type of bulbs did you order from vleds? How do you like the performance?
I also wanted to swap out the brake light bulbs & the rear turn signal bulbs. That would be cheaper than changing the entire housing with the LED lights ... although those do look sweet.
Old Oct 8, 2010 | 05:50 AM
E46byeRAhi's Avatar
you'll need 10ohm load resistors
Old Oct 8, 2010 | 07:29 AM
komilp13's Avatar
Oh so the LED bulbs are not a straight plug-n-play? I couldn't find any 10ohm resistors on vleds website?
Old Oct 8, 2010 | 07:33 AM
E46byeRAhi's Avatar
you only need the resistors for brake bulbs/turn signal bulbs. unless you find some with built in load resistors (so hard to find, and if you do find them, they probably won't fit through the same opening as the oem bulb, and if they do, they'll be 5x more expensive than regular led bulbs). you can get load resistors from amazon or even pepboys/autozone, i have Putco load resistors for front blinkers with 360° 30-smd LEDs. i've shopped around and gotten the LEDs that claim to have 'built in resistance' but they still cause a hyperblink problem.
Old Oct 8, 2010 | 07:40 AM
komilp13's Avatar
Originally Posted by buddy712
I use 'superbrightleds.com'. They have good prices and have so far been very reliable.
Did you have to purchase a separate load resistors with your bulbs ?
Old Oct 8, 2010 | 09:14 AM
buddy712's Avatar
You will only need resistors for turn signal bulbs. Interior and marker lights you will be fine with just the LED bulb
Old Nov 15, 2010 | 08:51 PM
kamijitsu's Avatar
Can someone please help a noob!!
The parking light (amber far outer corner of headlight) in order to swap out, which one is it? The grey rectangular looking one or the white circular looking one? When looking at all the connectors..
Old Nov 15, 2010 | 11:34 PM
T67@20ART's Avatar
I just replaced mine, difficult to get to, but I think it should be the grey one, closest to whatever corner, plus if you wiggle it you can see the corner light move a bit, so just twist counter clock and it comes off.
Old Nov 16, 2010 | 12:19 PM
kamijitsu's Avatar
^ thanks, you got to yours from the top? removing fuse box on driver side and resv tank on passenger? or did you go through wheel wells like the manual indicated?
Old Jan 16, 2011 | 11:24 AM
evox23's Avatar
+1 i need to do this one sometime soon...is it from the top or from the wheel wells? thanks
Old Jan 22, 2011 | 02:22 PM
evox23's Avatar
Unhappy parking light
i tried it this afternoon and i dont want to break it, but do i have to turn it or just pull it out straight...
Old Jan 22, 2011 | 08:31 PM
08Lancer89's Avatar
I ordered the 194 size. No resisters just take the old ones out and plug in the new ones. If the don't light up turn the led around and it should work. The ones I got where the high power 194s the brightest they make.
08Lancer89's Avatar
You have to turn it like the other blubs then pull it out.
Old Jan 22, 2011 | 08:35 PM
08Lancer89's Avatar
The top it's not as hard as u guys are making it sound. It's very simple. Look in you owners manual too it will help guide u.
Old Jan 22, 2011 | 08:48 PM
08Lancer89's Avatar
You sir are correct.
