Parking Corner Light
Hey guys,
so our parking light went out and when we took our car in for service to check a check engine light.. they told us that it'll cost 55 for labour to change the bulb cause you have to take apart the entire housing..
is this right?
i havent looked into it.. i am gonna go home and check the manual
but this was strange they told my wife this.
is this right?
The parking light in the headlight is easy. Just reach back there and twist the connector and pull it out the bulb will come with. After that just replace with the 194 blub of your choice then twist and push back in until locked. Simple as that. If it's the fender turn lights. Push back then lift the frot up to remove. If this blub is bad you do have to replace the whole thing not sure if you could just replace the blub inside or not. Hope this helps.
your tellin me the fender white covered parking lights just slide back and pop out? if so i had a lil project for those guys! i just didnt know how i was going to get them off there lol
Why dont you just pop your hood and look?
It takes about 1 minute to do both and replace with a 194 bulb. Personally i took mine out because it looks better with my hids without a city light.
ya i wanted to black mine out as well, just didnt know how to get em off to do it, seemed like it needed to be undone from inside the other side of the wheel well or something where i could not get to it without a buncha work. But knowing this ill have it done prolly within the week,
Usually I don't trust the people on ebay .. but I will have to check it out.
I found it easier to reach them from the top. I just tapped into the parking lights to hook up some LED strips. Is there any other place these type of bulbs are used?
i believe licence plate light bulbs are the same. and they're just LED's. you can tell the quality from the picture usually so ebay shouldn't be a big deterrent. i find the other websites that people listed on this thread overpriced for LEDs. look at dealextreme.com too for what prices should be like
