Engine Bay Vibrations and such
Old Dec 16, 2010 | 07:00 AM
Psycho09RA's Avatar
Just curious if any other 2009+ RA owners notice that the heat shielding or something else in the engine bay resonates and makes a horrible vibration sound at ~2500-3000 RPM in temperatures below 40 F.
It seriously is driving me insane when I have to listen to it while driving and yes one way to alleviate this issue is to turn up the radio ! I have a feeling that it is the heat shielding that curves outward from the firewall, but I'm not sure.
Anyone else notice this? Any thoughts?
Old Dec 16, 2010 | 07:16 AM
mikesim's Avatar
No vibration/rattle here. I am pretty sensitive to that stuff too.
I would check (when the car is cold) which shield is loose and try to tighten it down.
Old Dec 16, 2010 | 07:51 AM
DatRAzn's Avatar
Only vibrations I hear is the ice rattling by the wiper blades, . I haven't heard anything in the engine bay/heat shield area though.
Old Dec 16, 2010 | 10:01 AM
velocityhead's Avatar
I've been hearing some more rattling in sub-freezing temperatures, but as far as I can tell, mine's coming from the dash/glovebox area.
Old Dec 16, 2010 | 10:10 AM
Westbound&down's Avatar
I had a dragging sound the other day. Turned out to bethe plastic under carriage . For some reason (haha its cause im so low) it got beat up and started falling off in pieces.
Old Dec 16, 2010 | 01:34 PM
stfuad's Avatar
Why not just take off the shielding?
Old Dec 16, 2010 | 02:28 PM
Dunno about Syracuse, but up north we have a lot of snow, salt, sand, gravel, etc... I'd prefer these things not enter my engine bay.
Old Dec 16, 2010 | 03:29 PM
jan_ralliart's Avatar
Might be the stock downpipe heatshield if you hear it from the firewall area
Old Dec 17, 2010 | 06:49 AM
Psycho09RA's Avatar
Well, I feel that I have found the cause. I checked the heat shielding around the manifold and it felt loose. Checked the bolts holding the shield in place and they were tight. Removed the shielding and the sound is not near as bad as it was. I still hear a slight buzzing sound from shielding that is underneath the big heat shield, but that will be fixed with a bolt and a washer or two.
So my initial thought was incorrect, the heat shield coming off the firewall had nothing to do with the resonating sound.
Old Dec 17, 2010 | 09:11 AM
evil03's Avatar
come to think of it i have a cluck under the hood i can find! on when the car is warming up once its at normal operation temperature its gone... any clue?
Old Dec 17, 2010 | 12:20 PM
Veronica's Avatar
Your chickens have come to roost!
Drive for twenty minutes, baste, drive another twenty minutes, and serve with rice.
Old Dec 17, 2010 | 01:18 PM
2010 Rallihead's Avatar
I hate having to hear all the interior vibrations coming from the plastic dash and console we have... especially when you have an exhaust!!!
Old Dec 18, 2010 | 10:07 AM
Doarrival's Avatar
No vibrations...check the heat shield on the turbo
Old Dec 18, 2010 | 02:43 PM
Psycho09RA's Avatar
Re-installed 2 bolts with some washers to tighten the remaining heat shield on the upper downpipe assembly. So far so good, as I don't hear anything now!
I will know by tomorrow if it fixed my resonation problem for good. I'll keep everyone updated.
Old Dec 19, 2010 | 07:35 PM
Slee256's Avatar
Wow, you better see a doctor right away!
